hanserik
Nov 20, 2012Follower
Can not turn off my ReadyNAS Duo
I am using my ReadyNAS Duo to store picture and music files. I have had acces to it from four different computers in my local network. The computers have different OS; Windows XP, Windows Vista and ...
vandermerwe
Feb 01, 2014Master
File size is not a problem.
Can you delete your main logs as well as any backup job logs.
Checking the space in the OS partition would require ssh access.
An OS reinstall will almost certainly not help but is done using the boot menu. An OS reinstall does not destroy data, but you need to be careful not to do a factory default which will wipe your disks.
