hanserik
Nov 20, 2012Follower
Can not turn off my ReadyNAS Duo
I am using my ReadyNAS Duo to store picture and music files. I have had acces to it from four different computers in my local network. The computers have different OS; Windows XP, Windows Vista and ...
Feb 01, 2014Guru - Experienced User
Your duo v1 has a 2 GB OS partition that you can't see unless you use ssh.
Solomon22 wrote: You mean to Clear Logs in "Logs" Tab?
How do those texts affect the work of NAS?
In addition to the Linux software, logs are stored there, also ReadyDLNA media databases and some other apps databases. As that partition gets full, the NAS begins to misbehave in a variety of ways, and eventually fails to boot.
When you download the logs, the NAS attempts to create a zip file (also on the OS partition), which is then downloaded to the PC. So if the partition is nearly full, downloading the logs can push the NAS over the edge.
