hanserik
Nov 20, 2012Follower
Can not turn off my ReadyNAS Duo
I am using my ReadyNAS Duo to store picture and music files. I have had acces to it from four different computers in my local network. The computers have different OS; Windows XP, Windows Vista and ...
vandermerwe
Feb 09, 2014Master
I think you need to backup your data as a priority, then replace the disk.
You could test it using vendor tools, but this takes time, during which your data is at risk.
When you do insert a new disk, the reync will work the remaining disk quite hard, there is a small risk of failure of this disk. If this occurs during the resync you'll lose data, hence the advice to backup the unit now.
