hanserik's avatar
hanserik
Follower
Nov 20, 2012
Can not turn off my ReadyNAS Duo
I am using my ReadyNAS Duo to store picture and music files.
I have had acces to it from four different computers in my local network.
The computers have different OS; Windows XP, Windows Vista and Windows 7.
It has worked well until yesterday.
Suddenly the ReadyNAS Duo disappared from the network.
I can not see it from Explorer and I can not find it with RAIDar.
I have upgraded RAIDar to version (I can not find the version number?).
I have the computer with RAIDar on the same part of the network as the ReadyNAS Duo.
I have tried to turn off ReadyNAS Duo, but it does not react on my pushing the button on the front.
Both green lamps are green with solid light. (I have two discs mirrored).
What can I do?
I have very importend data on my ReadyNAS.
/Hans
  • Thanks vandermerwe for the support. I have now made numerous disk test including both the fast and long from the manufacturer (Seagate) and no errors where found. I'll make a back-up any way, but I'll continue using the disks I have.
    I still have the same problem with being unable to turn off the NAS in a controlled way. I just have to pull the plug. Any other ideas of what it could be? Could this be linked to the problem I have with losing the connection on the network, or is that very unlikely?
  • Has a real answer ever been found to this problem? I see questions/answers going back to 2009 but none seem to answer my problem:- I press and hold the START button waiting for the lights to flash - they never do! I can hold the button until my finger gets very sore and still the lights don't flash!!
    I have had my ReadyNAS for mant years, it works perfectly. Its about 80% full and tends to stay at that point, once a month I 'prune' the data stored and move old and unused stuff to DVD. But I would love to be able to switch the thing OFF without just pulling the plug. Help would be MUCH appreciated, I'm no geek so words of one sylable are the best, but I'll try to follow any instructions to sort this out.
    BobC
    • StephenB's avatar
      I haven't tried powering down with the power switch for quite a while.  Usually I shut it down from frontview - is that an option for you?
ProSupport for Business
