JMehring
Sep 29, 2013Apprentice
Can 'Recycle Bin' be enabled for CIFS and OS 6.1.2 on a 314?
The older 4.x version of the OS allowed a Recycle Bin when using CIFS. Is this possible on the new OS 6.1.2? I noticed a recycle.conf file in '/data/._share/media' containing: 25000,0
JMehring
Nov 20, 2013Apprentice
What I did was created this File:
Then I edited it to include 2 of my existing shares that I want to have 'Recycle Bin' bin enabled:
Now you need to reload the config file. The only way I could figure out how to do this was go to the frontview web interface -> Shares and edit one of your current shares changing something so when you press OK, it will reload config file (I just kept toggling ftp on and off when testing).
Then, just run:
It should list all your shares and show the recycle: parameters for the sections you wanted.
Note, I use the name 'Recycle Bin', but you could choose another like '.trash'
/etc/frontview/samba/addons/addons.conf
-rw-r--r-- 1 admin admin 556 Nov 6 00:43 addons.conf
[bitcasa]
vfs objects = recycle
recycle:repository = Recycle Bin
recycle:keeptree = yes
recycle:versions = no
[media]
Then, just run:
testparm
