JMehring
Sep 29, 2013Apprentice
Can 'Recycle Bin' be enabled for CIFS and OS 6.1.2 on a 314?
The older 4.x version of the OS allowed a Recycle Bin when using CIFS. Is this possible on the new OS 6.1.2? I noticed a recycle.conf file in '/data/._share/media' containing: 25000,0
Mar 22, 2014Guru - Experienced User
Select system, then the settings tab. The top section lists services, ssh is one of them. You need to enable that. Then use putty (or equivalent) to access the NAS. Logon is root, the password is your NAS admin password.
An alternative is to download the config settings (zip file) to your PC, make the change in the zip file, and then upload the new configuration. The config backup/restore is also on the settings tab.
Either way the files need to use the linux formatting convention, which is not compatible with a PC. One way to preserve the formatting is to use a freeware editor called notepad++ (http://notepad-plus-plus.org/). DON'T use notepad or wordpad on your PC - it is possible to brick your NAS if you use the windows format.
