JMehring
Sep 29, 2013Apprentice
Can 'Recycle Bin' be enabled for CIFS and OS 6.1.2 on a 314?
The older 4.x version of the OS allowed a Recycle Bin when using CIFS. Is this possible on the new OS 6.1.2? I noticed a recycle.conf file in '/data/._share/media' containing: 25000,0
JMehring
Jun 07, 2014Apprentice
Did you try rebooting windows after applying the recycle bin configuration? It should work no matter what OS you are using since it is the samba/cifs share doing the work.
Personally I can not test this out since I do not have windows
