Piglet
Dec 17, 2014Luminary
Cancel a defrag
I started a defrag on my RN104 about 60h ago and it still hasn't finished. It has so far eaten up about 70GB and I'm getting low on free space, so I want to move files off the NAS to make more room fo...
vandermerwe
Dec 17, 2014Master
Does the GUI give a suggestion as to how much longer it has left.
I would leave it alone, if you must shut down I'd do it using the GUI. The OS should then prevent a shutdown that would cause a problem. Why do you want to do it using ssh?
