Piglet
Dec 17, 2014Luminary
Cancel a defrag
I started a defrag on my RN104 about 60h ago and it still hasn't finished. It has so far eaten up about 70GB and I'm getting low on free space, so I want to move files off the NAS to make more room fo...
mdgm-ntgr
Dec 21, 2014NETGEAR Employee Retired
6.2 didn't enable CoW. It added the option to disable CoW. But as you already understand disabling CoW does not affect existing files.
One option would be to create new shares, copy your data into those shares and then delete the original shares.
When you run lsattr on a file you will see if CoW is enabled or not.
