jasons6930
Feb 02, 2012Aspirant
Cannot Access Duo!! Case Number 17823755
Hi all, I have an original RND and i cannot access it at all from any of my Macbooks. It has been working fine doing time machine back ups etc. I has an email that a resync was needed which i...
mdgm-ntgr
Feb 07, 2012NETGEAR Employee Retired
So disk 2 was fine and booted fine in the NAS by itself? Suggest you backup your data ASAP if you haven't already.
Does sound like disk 1 is well and truly dead.
Use one of the codes from this page: http://www.seagate.com/staticfiles/support/seatools/seatools-test-codes.html
Use e.g. "6FD1A1AE". I wouldn't use the Apple code as the drive was from the NAS, not the Mac.'
Well you can only really confirm the disk is bad by putting it inside a PC and testing it using SeaTools that way, but your NAS hanging the way it did indicates you almost certainly have a bad disk.
