jasons6930
Feb 02, 2012Aspirant
Cannot Access Duo!! Case Number 17823755
Hi all, I have an original RND and i cannot access it at all from any of my Macbooks. It has been working fine doing time machine back ups etc. I has an email that a resync was needed which i...
Feb 07, 2012Guru - Experienced User
Actually, they will replace it if you use one of the codes in mdgm's post. Though you do need to be sure the drive is bad.
Try also downloading Western Digital's Lifeguard - you can use it to see the SMART parameters.
