jasons6930
Feb 02, 2012Aspirant
Cannot Access Duo!! Case Number 17823755
Hi all, I have an original RND and i cannot access it at all from any of my Macbooks. It has been working fine doing time machine back ups etc. I has an email that a resync was needed which i...
jasons6930
Feb 07, 2012Aspirant
Thanks ill look into that.
WRT te codes, yes they will replace it under warranty if it throws back a code.
The problem is, at the moment with the basic tests, its not finding anything.
I have started a long test so hopefully that might help.
