lschelvis
Feb 19, 2011Aspirant
Cannot connect to Frontview
Hi all, The last days I cannot connect to frontview anymore. Whenever I go to http://192.168.2.147/admin (this is the correct IP address btw) I get the error "Internet Explorer cannot display the w...
mdgm-ntgr
Feb 19, 2011NETGEAR Employee Retired
What version of RAIDiator (can see under Info - far right - column in RAIDar)?
What do you mean by soft reset? Have you tried a firmware re-install? See http://www.readynas.com/forum/faq.php#How_do_I_re-install_the_firmware%3F
I'd suggest contacting technical support and posting your case in this thread. Use an Online Submission if more than 90 days since purchase.
