lschelvis
Feb 19, 2011Aspirant
Cannot connect to Frontview
Hi all, The last days I cannot connect to frontview anymore. Whenever I go to http://192.168.2.147/admin (this is the correct IP address btw) I get the error "Internet Explorer cannot display the w...
mdgm-ntgr
Feb 19, 2011NETGEAR Employee Retired
So you're using the BitTorrent add-on included in the firmware?
I'd suggest contacting tech support for help and posting your case number as suggested above.
