lschelvis
Feb 19, 2011Aspirant
Cannot connect to Frontview
Hi all, The last days I cannot connect to frontview anymore. Whenever I go to http://192.168.2.147/admin (this is the correct IP address btw) I get the error "Internet Explorer cannot display the w...
kuttenmann
May 11, 2011Aspirant
Is there any solution to this issue, yet? It seems as if a couple of users run into this issue - including me...
Btw.: Also for me, all services but HTTP(S)/Frontview work well. Even the web interface of Bittorrent can still be accessed. Port scanning also shows all services running as expected - except HTTP(S). The problem started showing up after setting a new secondary port for the HTTP(S) service although the new port was at 10000+ and unequal to any of the already used ports, e.g. by the Bittorrent web interface.
Firmware re-install as mentioned earlier in this thread also did not help.
