lschelvis
Feb 19, 2011Aspirant
Cannot connect to Frontview
Hi all, The last days I cannot connect to frontview anymore. Whenever I go to http://192.168.2.147/admin (this is the correct IP address btw) I get the error "Internet Explorer cannot display the w...
kuttenmann
Jun 01, 2011Aspirant
Bittorrent is also activated on my Duo although I am pretty sure that I de-activated it under 4.1.6. As I mentioned before, maybe it's just a port clash between Frontview and the Bittorrent web client. I will check whether Frontview is accessible for some time just after reboot. Maybe there is even enough time to disable Bittorrent?!
