lschelvis
Feb 19, 2011Aspirant
Cannot connect to Frontview
Hi all, The last days I cannot connect to frontview anymore. Whenever I go to http://192.168.2.147/admin (this is the correct IP address btw) I get the error "Internet Explorer cannot display the w...
Sep 12, 2012Guru - Experienced User
You should start your own thread, and describe your setup and problem with some more details.
RN2000 wrote: Hi,
I note this long discussion didn't result in a successful resolution.
Has anyone solved this problem? I am still experiencing it with firmware 4.1.9.
Does a Factory Reset resolve the problem of Frontview crashing?
Thanks
Factory reset completely rebuilds the duo, losing your configuration, add-ons, and all your data.
