sevilla315's avatar
sevilla315
Cannot connect to ReadyNas from Surface Pro
I am trying to connect to my old ReadyNas Pro 6 from my daughter's Surface Pro and I'm getting an error:   You can't connect to the file share because it's not secure. This share requires the obs...
  • DaneA's avatar
    May 03, 2018
    @sevilla315,
    I just want to follow-up on this.  Let us know if you have further inquiries.
    Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
