Maximillion's avatar
Maximillion
Cannot connect after newest firmware update for Microsoft Surface Pro 3
Hi, I have upgraded my Surface Pro 2 to Windows 10... had no issues connecting to R7000 on 5G band. After upgrading the R7000 firmware to the latest version (V1.0.4.30_1.1.67) I am now having issues connecting on the 5G band. Tablet must be adjacent to the router to connect on 5G band however once connected is connection is maintained at a distance (approx 50 feet). However if I choose the 2.4GH band I have no problem establishing initial connection at a distance. Is anyone else experiencing this issue and is there any fix?
Thanks!
  • Thanks a bunch, I went through all the processes of "Factory Reset" and that certainly didn't help. I took your advice and instructions on reverting back to 1.0.4.28 and it worked like a charm!
    I now connect my Surface tablet automatically at a distance of 50 feet or so through 3 walls out on my deck (as far as I've ventured so far) no problemo!
    With the latest firmware I had to be sitting next to the router. The latest firmware really is baaad!
    Thank sagain for your help!
  • Did you factory reset the R7000, after the  firmware upgrade?
    • vphagura's avatar
      vphagura
      Tutor
      Why would you have to do a factory reset just after appling a firmware upgrade?
      I'm running into the same issue as mentioned in the above post. I had to revert the upgrade back to V1.0.4.28_1.1.64
      • Babylon5's avatar
        Babylon5
        NETGEAR Employee Retired
        Step 1 of the firmware upgrade instructions states “Write down all the settings which you changed from the default values, since you may need to re-enter them manually.”
        This is a general statement that is included in practically all firmware upgrade instructions, and it’s there for the purpose of factory resetting if issues arise. It’s quite possible that a firmware upgrade can be issue free, and a factory reset is not required, but hundreds of posts on the Netgear forums over the years have had issues resolved simply by factory resetting and manually re-configuring following a firmware upgrade. There are also rare occasions, particularly where new functionality has been added, where the upgrade instructions will require a factory reset.
