Eldon1
Jun 19, 2012Follower
Cannot find a way to extract files locally.
Hi Guys, Sorry if the question is posted in the wrong section but i would really appreciate some assistance please. I am a very new user of the ReadyNas product and most probably am not even usi...
mdgm-ntgr
Jul 03, 2012NETGEAR Employee Retired
I think Slasky means EnableRootSSH.
Using the command line just to do things like unrar files would be fine so long as you do it in one of your shares not on the OS partition.
If you accidentally delete files or something like that via SSH then support would be unable to help with that.
