Bacelo
Aug 20, 2008Aspirant
Can't access C and home - need help
Hi Guys :wink: I have the problem that I'm not able to access "C" and "home" which is shown in the network area of windows. I remember that I was able to access the C root and also home at the b...
Bacelo
Thanks for the reply.
I know, and that's what I'm trying, but I can't access C and home using the same login data from the frontview. :cry:
ewok wrote: You'll need to access the C volume using the admin login credentials (the username and password you used to access Frontview).
