Bacelo
Aug 20, 2008Aspirant
Can't access C and home - need help
Hi Guys :wink: I have the problem that I'm not able to access "C" and "home" which is shown in the network area of windows. I remember that I was able to access the C root and also home at the b...
ewok
May 16, 2011NETGEAR Expert
skins wrote:
I'm getting the above problem but I *have* changed the admin password (no other user accounts) and I get "the local device name is already in use" when trying to map the drive as above using cmd. (running 4.1.7 on a duo).
It sounds like whatever drive name you're trying to use is already in use.
