bshannon
Apr 21, 2017Aspirant
Can't backup TiVo Bolt using ReadyDLNA
Running 6.6.1 firmware, I'm trying to set up ReadDLNA to backup my TiVo Bolt. It's already set up to backup my TiVo Roamio and Series 3 so I know the Media Access Key is correct. However, when I c...
JennC
Apr 26, 2017NETGEAR Employee Retired
Hello bshannon,
Honestly, I'm not really familiar how it looks like but I found that that the engineering is already aware that ReadyNAS' ReadyTiVO does not work with Bolt. This is something that they are still fixing.
bshannon
Apr 27, 2017Aspirant
Ah, ok, I'm glad it's a known problem. Thanks for the response. I guess I just need to wait for the solution to be available...
