chi100v
Feb 02, 2017Aspirant
Can't connect to admin page 6.6.1
Yesterday I install BitTorrent Sync on my device, reboot system and now I cant connect to admin page. System ver. 6.6.1 Please help.
chi100v
Feb 07, 2017Aspirant
Can someone explain how fix it?
- mdgm-ntgrFeb 07, 2017NETGEAR Employee Retired
Just sent you a PM
- Tommo2008Mar 03, 2017Aspirant
Hi Mdgm,
Im having the same issue with accessing the webui. I see that other users have disabled antivirus however im unable to access the web ui to do this. Can i do it via ssh?
Doing a bit of self investigation I ran the following cmd:
systemctl status apache2
got the following:
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset:
enabled)
Active: failed (Result: exit-code) since Fri 2017-03-03 21:11:15 G
MT; 10min ago
Process: 2959 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exit
ed, status=1/FAILURE)
Process: 2577 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCES
S)
admand folowed by:
systemctl restart apache2
and got the following response:
Failed to restart apache2.service: The name org.freedesktop.PolicyKit1 was not provided by any .service files
See system logs and 'systemctl status apache2.service' for details.Any help will be great as it was working fine until the other day!
Thanks
- Ki_Adi_MundiMar 09, 2017NETGEAR Employee Retired
sounds like some file lost, may try a os reinstall by boot menu ?
