MrLondon
Oct 16, 2017Aspirant
Can't connect to admin page
Hello unable to connect to my admin page, tried 3 different browers and restarting, i get as far as the login page. any ideas?
MrLondon
Oct 17, 2017Aspirant
only app installed and running is Transmission.
now installing 6.8.1
will post results
MrLondon
that seems to be successful, how can i install 6.9.0-RC1 ?
also im currently running 4 x 1TB and need more space,
is there a list of compatible drives?
- StephenBOct 17, 2017Guru - Experienced User
You probably don't need to install it if you have admin access again. However, if you want to, you get download the firmware from here: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-9-0-RC1/m-p/1365775#M9752, and then manually install it from system->settings.
There is, but the simple answer is to use WDC Red or Seagate Ironwolf models. These are NAS-purposed drives - enterprise class are faster, but your entry-level NAS can't take advantage of that speed anyway. I use WD60EFRX and WD80EFZX in my two RN52x NAS. I've tried the 1 TB Ironwolf in my RN102, and it works well also.
If you are looking at very large drives (5 TB and larger), than check the mounting specs. Ideally you'll have something with side center holes. You can work around that, but it's simplest to avoid it.
The full HCL is here: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
