borisw37
May 31, 2015Aspirant
Can't connect to NV+ V2, RAIDar finds it
I've moved my ReadyNAS NV+ V2 to a new home network (different router Zoom 5352). - ReadyNAS boots up and displays it's IP address - RAIDar.exe finds the NAS and shows status as healthy, all is goo...
vandermerwe
May 31, 2015Master
Ok.
What are the IP addresses of the new router, the readynas and the PC?
They should all have the same 3 digits, eg. 192.168.1.x, or 192.168.2.x. Do they?
Was the readynas network setting dhcp or had you set a static address?
Can you access the admin pages through raidar ?
You can do an OS reinstall using the boot menu which will reset the network settings to dhcp, but it should be possible to fix this without doing that.
