falco1
Jan 01, 2018Aspirant
Cant connect to ReadyNas Pro SMB1 Protocol ??
My readyNas Pro has being going great for quite a few years. I have three computers that connect to it, a laptop and two desktops. Last week after the latest windows 10 updates, both desktops couldn...
- Jan 01, 2018
You can enable the SMBv1 client on the desktop systems by opening CMD (right-click and "run as administrator").
Then enter
sc.exe config lanmanworkstation depend= bowser/mrxsmb10/mrxsmb20/nsi
sc.exe config mrxsmb20 start= autoLonger term, you probably should look into installing the NFS client on your PCs - that will give you an alternative to SMB1.
Another option is to upgrade your Pro to run OS-6. That will require a factory reset, so you would need to restore your data from backup. OS-6 support SMBv3.
Jan 01, 2018Guru - Experienced User
Then enter
