dacarson
Jun 19, 2024Aspirant
Can't destroy/erase raid volume
Hi, I had a very very similar problem to this one: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/The-volume-data-encountered-an-error-and-was-made-read-only-It/m-p/2161969 I...
- Jun 19, 2024
You can start completely over by doing a factory default. You can do this from the boot menu, or from the system->settings screen.
This will reformat the disks, and do a fresh install.
Jun 19, 2024Guru - Experienced User
