Bubba-Ho-Tep
Oct 17, 2020Aspirant
Can't Disable "Active Snapshot" When Trying to Expand Volume on ReadyNas Ultra 2
I currently have two 2-TB drives installed in my ReadyNas Ultra 2 Plus. Volumes are set to RAID Level X-RAID2. I am almost out of space so I decided to upgrade using 2 6-TB Seagate Ironwolf driv...
Bubba-Ho-Tep
Would this work barring the ssh route?
Since I haven't wiped the old 2TB drives, could I put them back in the ReadyNAS, perform a factory reset, and then put the 6TB drives back in or is that phantom snapshot locked onto the drive itself?
- StephenBOct 17, 2020Guru - Experienced User
The snapshot is on the disks (and was propagated to the new drives). So that won't help.
One alternative is to back up the data, do a factory reset, rebuild the NAS, and restore the files. If you do go this route, you should consider converting the NAS to run OS-6 while you are at it.
- Bubba-Ho-TepOct 18, 2020Aspirant
StephenB wrote:The snapshot is on the disks (and was propagated to the new drives). So that won't help.
I think this is the route I'll take. Does the Ultra 2 Plus do well with OS-6?
- StephenBOct 18, 2020Guru - Experienced User
Bubba-Ho-Tep wrote:
Does the Ultra 2 Plus do well with OS-6?Yes. Though we are recommending that you increase the RAM to at least 2 GB (since native OS-6 hardware has that much).
