Bubba-Ho-Tep
Oct 17, 2020Aspirant
Can't Disable "Active Snapshot" When Trying to Expand Volume on ReadyNas Ultra 2
I currently have two 2-TB drives installed in my ReadyNas Ultra 2 Plus. Volumes are set to RAID Level X-RAID2. I am almost out of space so I decided to upgrade using 2 6-TB Seagate Ironwolf driv...
Oct 18, 2020Guru - Experienced User
Bubba-Ho-Tep wrote:
Does the Ultra 2 Plus do well with OS-6?
Yes. Though we are recommending that you increase the RAM to at least 2 GB (since native OS-6 hardware has that much).
Bubba-Ho-Tep
Oct 19, 2020Aspirant
Since RAIDiator 4.2.31 was doing everything I needed it to do, I elected to stay with that.
I took your advice and made a backup copy of all of my data and then performed a factory reset. It looks like the NAS is have no problems reading the 6 TB drives (although the synch is taking forever due to, presumably, the sized).
Will post final result shortly.
Thanks!
