a0128958
Jan 19, 2015Aspirant
Can't Figure Out How to Set Up Remote Access to my Ultra 2
Hi. I have owned a ReadyNAS Ultra 2 for the past 3 years. I now own a ReadyNAS 312 too. Both have the latest firmware (Ultra 2 = RAIDiator 4.2.27) I use the Ultra 2 for media files storage. Loc...
RX
Jan 20, 2015Luminary
Kindly try this: Enable FTP on Standard File Protocols and set Authentication Mode as User. Then, enable FTP on each share you want to access via ReadyNAS Remote. Check if the shares will be accessible via ReadyNAS Remote.
Also, try to disable any software firewalls or anti-virus/es like Kaspersky, Norton, etc. that is installed on the PC where the ReadyNAS Remote Desktop software is installed.
