bootstrapbats
Mar 22, 2012Aspirant
Cant get a full scanning of my library using LMS or! SBS
I am at a end here! Since LMS 771 I can not scan my music library. There is the unexpected stop, always around 7000 files but it differs, and when searching for new files the scanner get stuck betw...
dkotkin
Apr 07, 2012Aspirant
I am completely frustrated. So 2 weeks ago I had everything working fine, but had a firmware issue. So after a few OS FW's I decided to do a complete factory reset and data reload. So my Ulta 4+ is back up and running. All data is back. But now Any version of LMS or even the older SBS will not do a complete scan. I have 40K+ of music and its stops at 351 ish each time. I have searched the logs to no avail, the scannner and server logs dont give me much infomation. I have removed files that it seems to stop on and then it still stops. I have tried full wipe scans, new music scans, and everything else. I have put the beta version radiator on (4.2.20-T42) and that hasnt fixed the issue. I even decided to downgrade the LMS to SBS (7.5) which was the version that previously worked before my factory reset, and it stops as well.
Any help from the forum would be appreciated.
DK
DK
