dbrami
Apr 26, 2023Aspirant
Can't go back to RW mode after system "protected" itself
Hi all, I've been struggling with this for a few weeks and can't use my NAS since this started. I was transferring some files to the NAS as a mounted "network drive" from my Macbook. I cancelled th...
- Apr 28, 2023
I am seeing two things.
One is that sde and sdf (disks 5 and 6) are showing some errors in disk_info.log
Device: sde Health Data: Current Pending Sector Count: 3 Uncorrectable Sector Count: 3 Device: sdf Health Data: Current Pending Sector Count: 5 Uncorrectable Sector Count: 4Raid-5 can't handle two disk failures, so that might be part of the puzzle here. Though these counts are small, it might be good to power down, and connect these disks to a PC (sata or USB dock). Test them with WD's dashboard software - running the long (full) non-destructive test. Label the disks as you remove them, so you can put them back in the right slot. Keep the NAS powered down until you replace the disks.
The other error (which is what is driving the read-only status is here:
Apr 08 10:50:54 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 1, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:54 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 2, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 3, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 4, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 5, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 6, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 7, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 8, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 9, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS error (device md127): bdev /dev/md127 errs: wr 10, rd 0, flush 0, corrupt 0, gen 0 Apr 08 10:50:58 BananaS kernel: BTRFS: error (device md127) in btrfs_commit_transaction:2249: errno=-5 IO failure (Error while writing out transaction) Apr 08 10:50:58 BananaS kernel: BTRFS info (device md127): forced readonlyOne thing that is odd is that I am not seeing any corresponding mdadm or raw disk errors in kernel.log - which normally we would see.
Not sure yet on what you might do with ssh, but I strongly recommend making a backup of any data you care about before attempting a repair. If it were my system, I'd start over with a fresh volume (factory default), because the repair might not fix everything.
dbrami
Apr 27, 2023Aspirant
Thanks for clear, categorical response!
BTW, it's a ReadyNAS 516 and I can't even find it on the product search when entering new topics.
I have no problem sharing the logs (I saved them on April 10th). This forum does not allow me to share zip files so here's URL:
<redacted>
If you think from looking at logs there's a simple command-line fix, that would be great.
If you don't, then it sounds like a need to buy 4TB of portable storage and copy my data over.
Netgear NAS == Never Again.
Apr 28, 2023Guru - Experienced User
There is privacy leakage when you post logs publicly. They should be sent using the private message (PM) facility in the forum. I downloaded yours, and then redacted your URL.
FWIW, you should have a backup strategy in place anyway (with any NAS). RAID isn't enough to keep your data safe. In general, if you don't have a proper backup, then you will eventually lose data - it's just a matter of when.
- StephenBApr 28, 2023Guru - Experienced User
- dbramiApr 28, 2023Aspirant
Thank you Guru StephenB for taking care of me - both with logs security and with your time to go through these and share your thoughts. Maybe the universe return the good karma you put out.
Will follow the the two same suggestions: back up the data (on an external drive), do a factory reset, and if possible, test each drive separately.
Best,
Daniel
