Retired_Member
Dec 01, 2015Can't shutdown Ready NAS rn104 with 6.1.4 RC3
Hello I have a VERY irritating problem. Everything time I turn off my NAS unit it just starts up again. After 3-4 sec. I have disk sleep turned off and auto standby schedule off. Anyone?????? Now I...
- Retired_MemberDec 04, 2015
I found the sollution myself!!!!
It was the addon VPN 1.5.0 that caused the change of MTU every system shutdown. As soon as i uninstalled it everything worked flawlessy again!!!!!
Retired_Member
Dec 02, 2015How do I turn off jumboframes. ???? Thanks for helping me out
Dec 02, 2015Guru - Experienced User
Did you ever turn them on? They are off by default.
Log in to the web ui, and select network. Click on the settings wheel next to the ethernet adapter icon.
On the "general" tab there's a field called "MTU". Set to 1500 (if it isn't already) and jumbo frames are off. The NAS might prompt for a reboot.
