gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
gonzonia
Oct 07, 2013Aspirant
From disk_usage.log
the data I posted previously came from upnp-av.log from earlier today (I've since rebooted and don't see anything similar)
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 647M 3.2G 17% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 5.5T 3.2T 2.3T 58% /c
/c/FTP_root 5.5T 3.2T 2.3T 58% /home/ftp/FTP_root
[2013/10/07 06:25:11] getifaddr.c:255: error: getifaddrs(): Too many open files
[2013/10/07 06:25:11] upnpevents.c:234: error: upnp_event_create_notify: socket(): Too many open files
