gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
dsm1212
Oct 07, 2013Apprentice
Well, this means something has more files open than are configured in the kernel :-). It may not be minidlna, but if you have ssh access you can see what minidlna has open by:
ps -C minidlna
to get the pid and then:
ls -l /proc/<PID>/fd
This will list all the open files by minidlna (which is the readydlna server on my system). Its possible on the new os, they may have changed the name of that process. My minidlna which is idle has 115 open (probably a dozen dlna clients in my house counting pc's, tv's, etc). You could check the other processes you have installed as addons to find the one using so many file handles.
Also, ulimit -n will tell you how many your system can have open. On my pro 6 running 4.2.24, ulimit -n shows 1024.
steve
ps -C minidlna
steve
