gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
dsm1212
Oct 08, 2013Apprentice
Hard to tell if the receiver is just the latest victim of the system being out of file handles or if it is the cause. The idle media servers in my house all seem to be having connections so to me it doesn't seem to be unexpected that the yamaha would be doing something. A device with some bad behavior interacting with minidlna could be the cause though I suppose. After the reboot, if the problem is gone you may want to stash a copy of the current list of files open so if the system gets in trouble again you can see what changed. I grabbed a full list with this command "ls -ld1 /proc/*/fd/* > /tmp/filesopen.lst".
steve
steve
