gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
gonzonia
Oct 09, 2013Aspirant
I'm not 100% sure the problem is solved but it hasn't shown up since yesterday. The only change I did was to the receiver. I turned Network Standby to off to limit network traffic when it's not in use. I'm also trying to remove unused services off the ReadyNAS. I had installed transmission in the past but didn't use it. Even though it was removed it appeared to be starting up in the logs. I reinstalled and removed to verify try to make sure. I think the iTunes server is still running too even though I have it unchecked in Frontview. I see it listed as a shared library in iTunes on my Mac.
