gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
gonzonia
Oct 15, 2013Aspirant
It happened again. I went to look at what files the process has open and here's what I got..I'm thinking it's not normal, but I don't know what it's doing it. I'll reboot for now. Any help would be appreciated.
total 0
lrwx------ 1 root root 64 2013-10-14 20:31 0 -> /dev/null
lrwx------ 1 root root 64 2013-10-14 20:31 1 -> /dev/null
lrwx------ 1 root root 64 2013-10-14 20:31 10 -> /var/cache/minidlna/files.db
lrwx------ 1 root root 64 2013-10-14 20:31 100 -> socket:[73245]
lrwx------ 1 root root 64 2013-10-14 20:31 1000 -> socket:[98676]
lrwx------ 1 root root 64 2013-10-14 20:31 1001 -> socket:[98709]
lrwx------ 1 root root 64 2013-10-14 20:31 1002 -> socket:[98714]
lrwx------ 1 root root 64 2013-10-14 20:31 1003 -> socket:[98719]
lrwx------ 1 root root 64 2013-10-14 20:31 1004 -> socket:[98724]
lrwx------ 1 root root 64 2013-10-14 20:31 1005 -> socket:[98729]
lrwx------ 1 root root 64 2013-10-14 20:31 1006 -> socket:[98734]
lrwx------ 1 root root 64 2013-10-14 20:31 1007 -> socket:[98739]
lrwx------ 1 root root 64 2013-10-14 20:31 1008 -> socket:[98744]
lrwx------ 1 root root 64 2013-10-14 20:31 1009 -> socket:[98749]
lrwx------ 1 root root 64 2013-10-14 20:31 101 -> socket:[73250]
lrwx------ 1 root root 64 2013-10-14 20:31 1010 -> socket:[98757]
lrwx------ 1 root root 64 2013-10-14 20:31 1011 -> socket:[98762]
lrwx------ 1 root root 64 2013-10-14 20:31 1012 -> socket:[98779]
lrwx------ 1 root root 64 2013-10-14 20:31 1013 -> socket:[98798]
lrwx------ 1 root root 64 2013-10-14 20:31 1014 -> socket:[98806]
lrwx------ 1 root root 64 2013-10-14 20:31 1015 -> socket:[98811]
lrwx------ 1 root root 64 2013-10-14 20:31 1016 -> socket:[98816]
lrwx------ 1 root root 64 2013-10-14 20:31 1017 -> socket:[98821]
lrwx------ 1 root root 64 2013-10-14 20:31 1018 -> socket:[98826]
lrwx------ 1 root root 64 2013-10-14 20:31 1019 -> socket:[98831]
lrwx------ 1 root root 64 2013-10-14 20:31 102 -> socket:[73255]
lrwx------ 1 root root 64 2013-10-14 20:31 1020 -> socket:[98836]
lrwx------ 1 root root 64 2013-10-14 20:31 1021 -> socket:[98841]
lrwx------ 1 root root 64 2013-10-14 20:31 1022 -> socket:[98847]
lrwx------ 1 root root 64 2013-10-14 20:31 1023 -> socket:[98852]
lrwx------ 1 root root 64 2013-10-14 20:31 103 -> socket:[73272]
lrwx------ 1 root root 64 2013-10-14 20:31 104 -> socket:[73302]
lrwx------ 1 root root 64 2013-10-14 20:31 105 -> socket:[73307]
lrwx------ 1 root root 64 2013-10-14 20:31 106 -> socket:[73312]
lrwx------ 1 root root 64 2013-10-14 20:31 107 -> socket:[73318]
lrwx------ 1 root root 64 2013-10-14 20:31 108 -> socket:[73323]
lrwx------ 1 root root 64 2013-10-14 20:31 109 -> socket:[73330]
lrwx------ 1 root root 64 2013-10-14 20:31 11 -> socket:[5143]
lrwx------ 1 root root 64 2013-10-14 20:31 110 -> socket:[73335]
lrwx------ 1 root root 64 2013-10-14 20:31 111 -> socket:[73340]
lrwx------ 1 root root 64 2013-10-14 20:31 112 -> socket:[73345]
lrwx------ 1 root root 64 2013-10-14 20:31 113 -> socket:[73350]
lrwx------ 1 root root 64 2013-10-14 20:31 114 -> socket:[73355]
lrwx------ 1 root root 64 2013-10-14 20:31 115 -> socket:[73360]
lrwx------ 1 root root 64 2013-10-14 20:31 116 -> socket:[73365]
lrwx------ 1 root root 64 2013-10-14 20:31 117 -> socket:[73398]
lrwx------ 1 root root 64 2013-10-14 20:31 118 -> socket:[73403]
lrwx------ 1 root root 64 2013-10-14 20:31 119 -> socket:[73408]
lrwx------ 1 root root 64 2013-10-14 20:31 12 -> socket:[5144]
lrwx------ 1 root root 64 2013-10-14 20:31 120 -> socket:[73414]
lrwx------ 1 root root 64 2013-10-14 20:31 121 -> socket:[73443]
lrwx------ 1 root root 64 2013-10-14 20:31 122 -> socket:[73448]
lrwx------ 1 root root 64 2013-10-14 20:31 123 -> socket:[73453]
lrwx------ 1 root root 64 2013-10-14 20:31 124 -> socket:[73460]
lrwx------ 1 root root 64 2013-10-14 20:31 125 -> socket:[73465]
lrwx------ 1 root root 64 2013-10-14 20:31 126 -> socket:[73470]
lrwx------ 1 root root 64 2013-10-14 20:31 127 -> socket:[73475]
lrwx------ 1 root root 64 2013-10-14 20:31 128 -> socket:[73480]
lrwx------ 1 root root 64 2013-10-14 20:31 129 -> socket:[73485]
lrwx------ 1 root root 64 2013-10-14 20:31 13 -> socket:[5145]
lrwx------ 1 root root 64 2013-10-14 20:31 130 -> socket:[73490]
lrwx------ 1 root root 64 2013-10-14 20:31 131 -> socket:[73496]
lrwx------ 1 root root 64 2013-10-14 20:31 132 -> socket:[73501]
lrwx------ 1 root root 64 2013-10-14 20:31 133 -> socket:[73506]
lrwx------ 1 root root 64 2013-10-14 20:31 134 -> socket:[73536]
lrwx------ 1 root root 64 2013-10-14 20:31 135 -> socket:[73541]
lrwx------ 1 root root 64 2013-10-14 20:31 136 -> socket:[73546]
lrwx------ 1 root root 64 2013-10-14 20:31 137 -> socket:[73579]
lrwx------ 1 root root 64 2013-10-14 20:31 138 -> socket:[73584]
lrwx------ 1 root root 64 2013-10-14 20:31 139 -> socket:[73603]
lr-x------ 1 root root 64 2013-10-14 20:31 14 -> anon_inode:inotify
lrwx------ 1 root root 64 2013-10-14 20:31 140 -> socket:[73636]
lrwx------ 1 root root 64 2013-10-14 20:31 141 -> socket:[73641]
lrwx------ 1 root root 64 2013-10-14 20:31 142 -> socket:[73646]
lrwx------ 1 root root 64 2013-10-14 20:31 143 -> socket:[73680]
lrwx------ 1 root root 64 2013-10-14 20:31 144 -> socket:[73685]
lrwx------ 1 root root 64 2013-10-14 20:31 145 -> socket:[73690]
lrwx------ 1 root root 64 2013-10-14 20:31 146 -> socket:[73695]
lrwx------ 1 root root 64 2013-10-14 20:31 147 -> socket:[73725]
lrwx------ 1 root root 64 2013-10-14 20:31 148 -> socket:[73730]
lrwx------ 1 root root 64 2013-10-14 20:31 149 -> socket:[73735]
lrwx------ 1 root root 64 2013-10-14 20:31 150 -> socket:[73765]
lrwx------ 1 root root 64 2013-10-14 20:31 151 -> socket:[73770]
lrwx------ 1 root root 64 2013-10-14 20:31 152 -> socket:[73775]
lrwx------ 1 root root 64 2013-10-14 20:31 153 -> socket:[73788]
lrwx------ 1 root root 64 2013-10-14 20:31 154 -> socket:[73823]
lrwx------ 1 root root 64 2013-10-14 20:31 155 -> socket:[73828]
lrwx------ 1 root root 64 2013-10-14 20:31 156 -> socket:[73834]
lrwx------ 1 root root 64 2013-10-14 20:31 157 -> socket:[73863]
lrwx------ 1 root root 64 2013-10-14 20:31 158 -> socket:[73868]
lrwx------ 1 root root 64 2013-10-14 20:31 159 -> socket:[73898]
lrwx------ 1 root root 64 2013-10-14 20:31 16 -> socket:[72415]
lrwx------ 1 root root 64 2013-10-14 20:31 160 -> socket:[73903]
lrwx------ 1 root root 64 2013-10-14 20:31 161 -> socket:[73908]
lrwx------ 1 root root 64 2013-10-14 20:31 162 -> socket:[73913]
lrwx------ 1 root root 64 2013-10-14 20:31 163 -> socket:[73943]
lrwx------ 1 root root 64 2013-10-14 20:31 164 -> socket:[73973]
lrwx------ 1 root root 64 2013-10-14 20:31 165 -> socket:[73978]
lrwx------ 1 root root 64 2013-10-14 20:31 166 -> socket:[74008]
lrwx------ 1 root root 64 2013-10-14 20:31 167 -> socket:[74013]
lrwx------ 1 root root 64 2013-10-14 20:31 168 -> socket:[74018]
lrwx------ 1 root root 64 2013-10-14 20:31 169 -> socket:[74054]
lrwx------ 1 root root 64 2013-10-14 20:31 17 -> socket:[72420]
lrwx------ 1 root root 64 2013-10-14 20:31 170 -> socket:[74059]
lrwx------ 1 root root 64 2013-10-14 20:31 171 -> socket:[74064]
lrwx------ 1 root root 64 2013-10-14 20:31 172 -> socket:[74069]
lrwx------ 1 root root 64 2013-10-14 20:31 173 -> socket:[74099]
lrwx------ 1 root root 64 2013-10-14 20:31 174 -> socket:[74104]
lrwx------ 1 root root 64 2013-10-14 20:31 175 -> socket:[74121]
lrwx------ 1 root root 64 2013-10-14 20:31 176 -> socket:[74151]
lrwx------ 1 root root 64 2013-10-14 20:31 177 -> socket:[74173]
lrwx------ 1 root root 64 2013-10-14 20:31 178 -> socket:[74178]
lrwx------ 1 root root 64 2013-10-14 20:31 179 -> socket:[74183]
lrwx------ 1 root root 64 2013-10-14 20:31 18 -> socket:[72428]
lrwx------ 1 root root 64 2013-10-14 20:31 180 -> socket:[74214]
lrwx------ 1 root root 64 2013-10-14 20:31 181 -> socket:[74219]
lrwx------ 1 root root 64 2013-10-14 20:31 182 -> socket:[74224]
lrwx------ 1 root root 64 2013-10-14 20:31 183 -> socket:[74229]
lrwx------ 1 root root 64 2013-10-14 20:31 184 -> socket:[74261]
lrwx------ 1 root root 64 2013-10-14 20:31 185 -> socket:[74266]
lrwx------ 1 root root 64 2013-10-14 20:31 186 -> socket:[74271]
lrwx------ 1 root root 64 2013-10-14 20:31 187 -> socket:[74276]
lrwx------ 1 root root 64 2013-10-14 20:31 188 -> socket:[74309]
lrwx------ 1 root root 64 2013-10-14 20:31 189 -> socket:[74314]
lrwx------ 1 root root 64 2013-10-14 20:31 19 -> socket:[72464]
lrwx------ 1 root root 64 2013-10-14 20:31 190 -> socket:[74319]
lrwx------ 1 root root 64 2013-10-14 20:31 191 -> socket:[74324]
lrwx------ 1 root root 64 2013-10-14 20:31 192 -> socket:[74357]
lrwx------ 1 root root 64 2013-10-14 20:31 193 -> socket:[74387]
lrwx------ 1 root root 64 2013-10-14 20:31 194 -> socket:[74392]
lrwx------ 1 root root 64 2013-10-14 20:31 195 -> socket:[74397]
lrwx------ 1 root root 64 2013-10-14 20:31 196 -> socket:[74402]
lrwx------ 1 root root 64 2013-10-14 20:31 197 -> socket:[74407]
lrwx------ 1 root root 64 2013-10-14 20:31 198 -> socket:[74412]
lrwx------ 1 root root 64 2013-10-14 20:31 199 -> socket:[74419]
lrwx------ 1 root root 64 2013-10-14 20:31 2 -> /dev/null
lrwx------ 1 root root 64 2013-10-14 20:31 20 -> socket:[72469]
lrwx------ 1 root root 64 2013-10-14 20:31 200 -> socket:[74449]
lrwx------ 1 root root 64 2013-10-14 20:31 201 -> socket:[74454]
lrwx------ 1 root root 64 2013-10-14 20:31 202 -> socket:[74459]
lrwx------ 1 root root 64 2013-10-14 20:31 203 -> socket:[74464]
lrwx------ 1 root root 64 2013-10-14 20:31 204 -> socket:[74469]
lrwx------ 1 root root 64 2013-10-14 20:31 205 -> socket:[74474]
lrwx------ 1 root root 64 2013-10-14 20:31 206 -> socket:[74480]
lrwx------ 1 root root 64 2013-10-14 20:31 207 -> socket:[74485]
lrwx------ 1 root root 64 2013-10-14 20:31 208 -> socket:[74490]
lrwx------ 1 root root 64 2013-10-14 20:31 209 -> socket:[74495]
lrwx------ 1 root root 64 2013-10-14 20:31 21 -> socket:[72474]
lrwx------ 1 root root 64 2013-10-14 20:31 210 -> socket:[74500]
lrwx------ 1 root root 64 2013-10-14 20:31 211 -> socket:[74517]
lrwx------ 1 root root 64 2013-10-14 20:31 212 -> socket:[74522]
lrwx------ 1 root root 64 2013-10-14 20:31 213 -> socket:[74527]
lrwx------ 1 root root 64 2013-10-14 20:31 214 -> socket:[74534]
lrwx------ 1 root root 64 2013-10-14 20:31 215 -> socket:[74539]
lrwx------ 1 root root 64 2013-10-14 20:31 216 -> socket:[74569]
lrwx------ 1 root root 64 2013-10-14 20:31 217 -> socket:[74574]
lrwx------ 1 root root 64 2013-10-14 20:31 218 -> socket:[74580]
lrwx------ 1 root root 64 2013-10-14 20:31 219 -> socket:[74585]
lrwx------ 1 root root 64 2013-10-14 20:31 22 -> socket:[72505]
lrwx------ 1 root root 64 2013-10-14 20:31 220 -> socket:[74590]
lrwx------ 1 root root 64 2013-10-14 20:31 221 -> socket:[74595]
lrwx------ 1 root root 64 2013-10-14 20:31 222 -> socket:[74600]
lrwx------ 1 root root 64 2013-10-14 20:31 223 -> socket:[74605]
lrwx------ 1 root root 64 2013-10-14 20:31 224 -> socket:[74610]
lrwx------ 1 root root 64 2013-10-14 20:31 225 -> socket:[74615]
lrwx------ 1 root root 64 2013-10-14 20:31 226 -> socket:[74620]
lrwx------ 1 root root 64 2013-10-14 20:31 227 -> socket:[74625]
lrwx------ 1 root root 64 2013-10-14 20:31 228 -> socket:[74630]
lrwx------ 1 root root 64 2013-10-14 20:31 229 -> socket:[74662]
lrwx------ 1 root root 64 2013-10-14 20:31 23 -> socket:[72510]
lrwx------ 1 root root 64 2013-10-14 20:31 230 -> socket:[74675]
lrwx------ 1 root root 64 2013-10-14 20:31 231 -> socket:[74688]
lrwx------ 1 root root 64 2013-10-14 20:31 232 -> socket:[74693]
lrwx------ 1 root root 64 2013-10-14 20:31 233 -> socket:[74698]
lrwx------ 1 root root 64 2013-10-14 20:31 234 -> socket:[74703]
lrwx------ 1 root root 64 2013-10-14 20:31 235 -> socket:[74708]
lrwx------ 1 root root 64 2013-10-14 20:31 236 -> socket:[74713]
lrwx------ 1 root root 64 2013-10-14 20:31 237 -> socket:[74718]
lrwx------ 1 root root 64 2013-10-14 20:31 238 -> socket:[74723]
lrwx------ 1 root root 64 2013-10-14 20:31 239 -> socket:[74728]
lrwx------ 1 root root 64 2013-10-14 20:31 24 -> socket:[72515]
lrwx------ 1 root root 64 2013-10-14 20:31 240 -> socket:[74733]
lrwx------ 1 root root 64 2013-10-14 20:31 241 -> socket:[74738]
lrwx------ 1 root root 64 2013-10-14 20:31 242 -> socket:[74744]
lrwx------ 1 root root 64 2013-10-14 20:31 243 -> socket:[74749]
lrwx------ 1 root root 64 2013-10-14 20:31 244 -> socket:[74756]
lrwx------ 1 root root 64 2013-10-14 20:31 245 -> socket:[74761]
lrwx------ 1 root root 64 2013-10-14 20:31 246 -> socket:[74766]
lrwx------ 1 root root 64 2013-10-14 20:31 247 -> socket:[74783]
lrwx------ 1 root root 64 2013-10-14 20:31 248 -> socket:[74813]
lrwx------ 1 root root 64 2013-10-14 20:31 249 -> socket:[74818]
lrwx------ 1 root root 64 2013-10-14 20:31 25 -> socket:[72520]
lrwx------ 1 root root 64 2013-10-14 20:31 250 -> socket:[74823]
lrwx------ 1 root root 64 2013-10-14 20:31 251 -> socket:[74828]
lrwx------ 1 root root 64 2013-10-14 20:31 252 -> socket:[74833]
lrwx------ 1 root root 64 2013-10-14 20:31 253 -> socket:[74838]
lrwx------ 1 root root 64 2013-10-14 20:31 254 -> socket:[74844]
lrwx------ 1 root root 64 2013-10-14 20:31 255 -> socket:[74849]
lrwx------ 1 root root 64 2013-10-14 20:31 256 -> socket:[74854]
lrwx------ 1 root root 64 2013-10-14 20:31 257 -> socket:[74859]
lrwx------ 1 root root 64 2013-10-14 20:31 258 -> socket:[74864]
lrwx------ 1 root root 64 2013-10-14 20:31 259 -> socket:[74871]
lrwx------ 1 root root 64 2013-10-14 20:31 26 -> socket:[72550]
lrwx------ 1 root root 64 2013-10-14 20:31 260 -> socket:[74876]
lrwx------ 1 root root 64 2013-10-14 20:31 261 -> socket:[74881]
lrwx------ 1 root root 64 2013-10-14 20:31 262 -> socket:[74886]
lrwx------ 1 root root 64 2013-10-14 20:31 263 -> socket:[74891]
lrwx------ 1 root root 64 2013-10-14 20:31 264 -> socket:[74896]
lrwx------ 1 root root 64 2013-10-14 20:31 265 -> socket:[74925]
lrwx------ 1 root root 64 2013-10-14 20:31 266 -> socket:[74943]
lrwx------ 1 root root 64 2013-10-14 20:31 267 -> socket:[74953]
lrwx------ 1 root root 64 2013-10-14 20:31 268 -> socket:[74958]
lrwx------ 1 root root 64 2013-10-14 20:31 269 -> socket:[74963]
lrwx------ 1 root root 64 2013-10-14 20:31 27 -> socket:[72555]
lrwx------ 1 root root 64 2013-10-14 20:31 270 -> socket:[74968]
lrwx------ 1 root root 64 2013-10-14 20:31 271 -> socket:[74973]
lrwx------ 1 root root 64 2013-10-14 20:31 272 -> socket:[74978]
lrwx------ 1 root root 64 2013-10-14 20:31 273 -> socket:[74983]
lrwx------ 1 root root 64 2013-10-14 20:31 274 -> socket:[74990]
lrwx------ 1 root root 64 2013-10-14 20:31 275 -> socket:[74995]
lrwx------ 1 root root 64 2013-10-14 20:31 276 -> socket:[75000]
lrwx------ 1 root root 64 2013-10-14 20:31 277 -> socket:[75005]
lrwx------ 1 root root 64 2013-10-14 20:31 278 -> socket:[75010]
lrwx------ 1 root root 64 2013-10-14 20:31 279 -> socket:[75016]
lrwx------ 1 root root 64 2013-10-14 20:31 28 -> socket:[72560]
lrwx------ 1 root root 64 2013-10-14 20:31 280 -> socket:[75021]
lrwx------ 1 root root 64 2013-10-14 20:31 281 -> socket:[75026]
lrwx------ 1 root root 64 2013-10-14 20:31 282 -> socket:[75031]
lrwx------ 1 root root 64 2013-10-14 20:31 283 -> socket:[75048]
lrwx------ 1 root root 64 2013-10-14 20:31 284 -> socket:[75053]
lrwx------ 1 root root 64 2013-10-14 20:31 285 -> socket:[75058]
lrwx------ 1 root root 64 2013-10-14 20:31 286 -> socket:[75063]
lrwx------ 1 root root 64 2013-10-14 20:31 287 -> socket:[75068]
lrwx------ 1 root root 64 2013-10-14 20:31 288 -> socket:[75073]
lrwx------ 1 root root 64 2013-10-14 20:31 289 -> socket:[75080]
lrwx------ 1 root root 64 2013-10-14 20:31 29 -> socket:[72590]
lrwx------ 1 root root 64 2013-10-14 20:31 290 -> socket:[75085]
lrwx------ 1 root root 64 2013-10-14 20:31 291 -> socket:[75091]
lrwx------ 1 root root 64 2013-10-14 20:31 292 -> socket:[75096]
lrwx------ 1 root root 64 2013-10-14 20:31 293 -> socket:[75101]
lrwx------ 1 root root 64 2013-10-14 20:31 294 -> socket:[75106]
lrwx------ 1 root root 64 2013-10-14 20:31 295 -> socket:[75139]
lrwx------ 1 root root 64 2013-10-14 20:31 296 -> socket:[75144]
lrwx------ 1 root root 64 2013-10-14 20:31 297 -> socket:[75149]
lrwx------ 1 root root 64 2013-10-14 20:31 298 -> socket:[75154]
lrwx------ 1 root root 64 2013-10-14 20:31 299 -> socket:[75159]
lr-x------ 1 root root 64 2013-10-14 20:31 3 -> pipe:[4793]
lrwx------ 1 root root 64 2013-10-14 20:31 30 -> socket:[72595]
lrwx------ 1 root root 64 2013-10-14 20:31 300 -> socket:[75164]
lrwx------ 1 root root 64 2013-10-14 20:31 301 -> socket:[75193]
lrwx------ 1 root root 64 2013-10-14 20:31 302 -> socket:[75198]
lrwx------ 1 root root 64 2013-10-14 20:31 303 -> socket:[75229]
lrwx------ 1 root root 64 2013-10-14 20:31 304 -> socket:[75236]
lrwx------ 1 root root 64 2013-10-14 20:31 305 -> socket:[75241]
lrwx------ 1 root root 64 2013-10-14 20:31 306 -> socket:[75274]
lrwx------ 1 root root 64 2013-10-14 20:31 307 -> socket:[75279]
lrwx------ 1 root root 64 2013-10-14 20:31 308 -> socket:[75284]
lrwx------ 1 root root 64 2013-10-14 20:31 309 -> socket:[75297]
lrwx------ 1 root root 64 2013-10-14 20:31 31 -> socket:[72600]
lrwx------ 1 root root 64 2013-10-14 20:31 310 -> socket:[75330]
lrwx------ 1 root root 64 2013-10-14 20:31 311 -> socket:[75335]
lrwx------ 1 root root 64 2013-10-14 20:31 312 -> socket:[75340]
lrwx------ 1 root root 64 2013-10-14 20:31 313 -> socket:[75373]
lrwx------ 1 root root 64 2013-10-14 20:31 314 -> socket:[75378]
lrwx------ 1 root root 64 2013-10-14 20:31 315 -> socket:[75384]
lrwx------ 1 root root 64 2013-10-14 20:31 316 -> socket:[75389]
lrwx------ 1 root root 64 2013-10-14 20:31 317 -> socket:[75422]
lrwx------ 1 root root 64 2013-10-14 20:31 318 -> socket:[75427]
lrwx------ 1 root root 64 2013-10-14 20:31 319 -> socket:[75446]
lrwx------ 1 root root 64 2013-10-14 20:31 32 -> socket:[72617]
lrwx------ 1 root root 64 2013-10-14 20:31 320 -> socket:[75479]
lrwx------ 1 root root 64 2013-10-14 20:31 321 -> socket:[75484]
lrwx------ 1 root root 64 2013-10-14 20:31 322 -> socket:[75489]
lrwx------ 1 root root 64 2013-10-14 20:31 323 -> socket:[75494]
lrwx------ 1 root root 64 2013-10-14 20:31 324 -> socket:[75527]
lrwx------ 1 root root 64 2013-10-14 20:31 325 -> socket:[75532]
lrwx------ 1 root root 64 2013-10-14 20:31 326 -> socket:[75537]
lrwx------ 1 root root 64 2013-10-14 20:31 327 -> socket:[75542]
lrwx------ 1 root root 64 2013-10-14 20:31 328 -> socket:[75573]
lrwx------ 1 root root 64 2013-10-14 20:31 329 -> socket:[75578]
lrwx------ 1 root root 64 2013-10-14 20:31 33 -> socket:[72647]
lrwx------ 1 root root 64 2013-10-14 20:31 330 -> socket:[75583]
lrwx------ 1 root root 64 2013-10-14 20:31 331 -> socket:[75588]
lrwx------ 1 root root 64 2013-10-14 20:31 332 -> socket:[75621]
lrwx------ 1 root root 64 2013-10-14 20:31 333 -> socket:[75626]
lrwx------ 1 root root 64 2013-10-14 20:31 334 -> socket:[75633]
lrwx------ 1 root root 64 2013-10-14 20:31 335 -> socket:[75638]
lrwx------ 1 root root 64 2013-10-14 20:31 336 -> socket:[75668]
lrwx------ 1 root root 64 2013-10-14 20:31 337 -> socket:[75697]
lrwx------ 1 root root 64 2013-10-14 20:31 338 -> socket:[75702]
lrwx------ 1 root root 64 2013-10-14 20:31 339 -> socket:[75707]
lrwx------ 1 root root 64 2013-10-14 20:31 34 -> socket:[72654]
lrwx------ 1 root root 64 2013-10-14 20:31 340 -> socket:[75712]
lrwx------ 1 root root 64 2013-10-14 20:31 341 -> socket:[75718]
lrwx------ 1 root root 64 2013-10-14 20:31 342 -> socket:[75723]
lrwx------ 1 root root 64 2013-10-14 20:31 343 -> socket:[75728]
lrwx------ 1 root root 64 2013-10-14 20:31 344 -> socket:[75786]
lrwx------ 1 root root 64 2013-10-14 20:31 345 -> socket:[75791]
lrwx------ 1 root root 64 2013-10-14 20:31 346 -> socket:[75796]
lrwx------ 1 root root 64 2013-10-14 20:31 347 -> socket:[75801]
lrwx------ 1 root root 64 2013-10-14 20:31 348 -> socket:[75806]
lrwx------ 1 root root 64 2013-10-14 20:31 349 -> socket:[75813]
lrwx------ 1 root root 64 2013-10-14 20:31 35 -> socket:[72660]
lrwx------ 1 root root 64 2013-10-14 20:31 350 -> socket:[75818]
lrwx------ 1 root root 64 2013-10-14 20:31 351 -> socket:[75823]
lrwx------ 1 root root 64 2013-10-14 20:31 352 -> socket:[75828]
lrwx------ 1 root root 64 2013-10-14 20:31 353 -> socket:[75834]
lrwx------ 1 root root 64 2013-10-14 20:31 354 -> socket:[75839]
lrwx------ 1 root root 64 2013-10-14 20:31 355 -> socket:[75856]
lrwx------ 1 root root 64 2013-10-14 20:31 356 -> socket:[75875]
lrwx------ 1 root root 64 2013-10-14 20:31 357 -> socket:[75883]
lrwx------ 1 root root 64 2013-10-14 20:31 358 -> socket:[75888]
lrwx------ 1 root root 64 2013-10-14 20:31 359 -> socket:[75893]
lrwx------ 1 root root 64 2013-10-14 20:31 36 -> socket:[72693]
lrwx------ 1 root root 64 2013-10-14 20:31 360 -> socket:[75923]
lrwx------ 1 root root 64 2013-10-14 20:31 361 -> socket:[75928]
lrwx------ 1 root root 64 2013-10-14 20:31 362 -> socket:[75933]
lrwx------ 1 root root 64 2013-10-14 20:31 363 -> socket:[75938]
lrwx------ 1 root root 64 2013-10-14 20:31 364 -> socket:[75945]
lrwx------ 1 root root 64 2013-10-14 20:31 365 -> socket:[75951]
lrwx------ 1 root root 64 2013-10-14 20:31 366 -> socket:[75956]
lrwx------ 1 root root 64 2013-10-14 20:31 367 -> socket:[75961]
lrwx------ 1 root root 64 2013-10-14 20:31 368 -> socket:[75966]
lrwx------ 1 root root 64 2013-10-14 20:31 369 -> socket:[75991]
lrwx------ 1 root root 64 2013-10-14 20:31 37 -> socket:[72698]
lrwx------ 1 root root 64 2013-10-14 20:31 370 -> socket:[75996]
lrwx------ 1 root root 64 2013-10-14 20:31 371 -> socket:[76001]
lrwx------ 1 root root 64 2013-10-14 20:31 372 -> socket:[76006]
lrwx------ 1 root root 64 2013-10-14 20:31 373 -> socket:[76035]
lrwx------ 1 root root 64 2013-10-14 20:31 374 -> socket:[76040]
lrwx------ 1 root root 64 2013-10-14 20:31 375 -> socket:[76045]
lrwx------ 1 root root 64 2013-10-14 20:31 376 -> socket:[76050]
lrwx------ 1 root root 64 2013-10-14 20:31 377 -> socket:[76055]
lrwx------ 1 root root 64 2013-10-14 20:31 378 -> socket:[76061]
lrwx------ 1 root root 64 2013-10-14 20:31 379 -> socket:[76068]
lrwx------ 1 root root 64 2013-10-14 20:31 38 -> socket:[72703]
lrwx------ 1 root root 64 2013-10-14 20:31 380 -> socket:[76073]
lrwx------ 1 root root 64 2013-10-14 20:31 381 -> socket:[76078]
lrwx------ 1 root root 64 2013-10-14 20:31 382 -> socket:[76083]
lrwx------ 1 root root 64 2013-10-14 20:31 383 -> socket:[76088]
lrwx------ 1 root root 64 2013-10-14 20:31 384 -> socket:[76093]
lrwx------ 1 root root 64 2013-10-14 20:31 385 -> socket:[76098]
lrwx------ 1 root root 64 2013-10-14 20:31 386 -> socket:[76111]
lrwx------ 1 root root 64 2013-10-14 20:31 387 -> socket:[76116]
lrwx------ 1 root root 64 2013-10-14 20:31 388 -> socket:[76121]
lrwx------ 1 root root 64 2013-10-14 20:31 389 -> socket:[76126]
lrwx------ 1 root root 64 2013-10-14 20:31 39 -> socket:[72708]
lrwx------ 1 root root 64 2013-10-14 20:31 390 -> socket:[76132]
lrwx------ 1 root root 64 2013-10-14 20:31 391 -> socket:[76149]
lrwx------ 1 root root 64 2013-10-14 20:31 392 -> socket:[76179]
lrwx------ 1 root root 64 2013-10-14 20:31 393 -> socket:[76184]
lrwx------ 1 root root 64 2013-10-14 20:31 394 -> socket:[76191]
lrwx------ 1 root root 64 2013-10-14 20:31 395 -> socket:[76196]
lrwx------ 1 root root 64 2013-10-14 20:31 396 -> socket:[76201]
lrwx------ 1 root root 64 2013-10-14 20:31 397 -> socket:[76206]
lrwx------ 1 root root 64 2013-10-14 20:31 398 -> socket:[76211]
lrwx------ 1 root root 64 2013-10-14 20:31 399 -> socket:[76216]
l-wx------ 1 root root 64 2013-10-14 20:31 4 -> pipe:[4793]
lrwx------ 1 root root 64 2013-10-14 20:31 40 -> socket:[72741]
lrwx------ 1 root root 64 2013-10-14 20:31 400 -> socket:[76221]
lrwx------ 1 root root 64 2013-10-14 20:31 401 -> socket:[76226]
lrwx------ 1 root root 64 2013-10-14 20:31 402 -> socket:[76232]
lrwx------ 1 root root 64 2013-10-14 20:31 403 -> socket:[76237]
lrwx------ 1 root root 64 2013-10-14 20:31 404 -> socket:[76242]
lrwx------ 1 root root 64 2013-10-14 20:31 405 -> socket:[76247]
lrwx------ 1 root root 64 2013-10-14 20:31 406 -> socket:[76252]
lrwx------ 1 root root 64 2013-10-14 20:31 407 -> socket:[76257]
lrwx------ 1 root root 64 2013-10-14 20:31 408 -> socket:[76262]
lrwx------ 1 root root 64 2013-10-14 20:31 409 -> socket:[76293]
lrwx------ 1 root root 64 2013-10-14 20:31 41 -> socket:[72746]
lrwx------ 1 root root 64 2013-10-14 20:31 410 -> socket:[76298]
lrwx------ 1 root root 64 2013-10-14 20:31 411 -> socket:[76331]
lrwx------ 1 root root 64 2013-10-14 20:31 412 -> socket:[76336]
lrwx------ 1 root root 64 2013-10-14 20:31 413 -> socket:[76341]
lrwx------ 1 root root 64 2013-10-14 20:31 414 -> socket:[76347]
lrwx------ 1 root root 64 2013-10-14 20:31 415 -> socket:[76352]
lrwx------ 1 root root 64 2013-10-14 20:31 416 -> socket:[76357]
lrwx------ 1 root root 64 2013-10-14 20:31 417 -> socket:[76362]
lrwx------ 1 root root 64 2013-10-14 20:31 418 -> socket:[76367]
lrwx------ 1 root root 64 2013-10-14 20:31 419 -> socket:[76372]
lrwx------ 1 root root 64 2013-10-14 20:31 42 -> socket:[72751]
lrwx------ 1 root root 64 2013-10-14 20:31 420 -> socket:[76377]
lrwx------ 1 root root 64 2013-10-14 20:31 421 -> socket:[76382]
lrwx------ 1 root root 64 2013-10-14 20:31 422 -> socket:[76387]
lrwx------ 1 root root 64 2013-10-14 20:31 423 -> socket:[76392]
lrwx------ 1 root root 64 2013-10-14 20:31 424 -> socket:[76399]
lrwx------ 1 root root 64 2013-10-14 20:31 425 -> socket:[76404]
lrwx------ 1 root root 64 2013-10-14 20:31 426 -> socket:[76410]
lrwx------ 1 root root 64 2013-10-14 20:31 427 -> socket:[76427]
lrwx------ 1 root root 64 2013-10-14 20:31 428 -> socket:[76432]
lrwx------ 1 root root 64 2013-10-14 20:31 429 -> socket:[76437]
lrwx------ 1 root root 64 2013-10-14 20:31 43 -> socket:[72756]
lrwx------ 1 root root 64 2013-10-14 20:31 430 -> socket:[76442]
lrwx------ 1 root root 64 2013-10-14 20:31 431 -> socket:[76447]
lrwx------ 1 root root 64 2013-10-14 20:31 432 -> socket:[76452]
lrwx------ 1 root root 64 2013-10-14 20:31 433 -> socket:[76457]
lrwx------ 1 root root 64 2013-10-14 20:31 434 -> socket:[76462]
lrwx------ 1 root root 64 2013-10-14 20:31 435 -> socket:[76467]
lrwx------ 1 root root 64 2013-10-14 20:31 436 -> socket:[76472]
lrwx------ 1 root root 64 2013-10-14 20:31 437 -> socket:[76477]
lrwx------ 1 root root 64 2013-10-14 20:31 438 -> socket:[76482]
lrwx------ 1 root root 64 2013-10-14 20:31 439 -> socket:[76490]
lrwx------ 1 root root 64 2013-10-14 20:31 44 -> socket:[72789]
lrwx------ 1 root root 64 2013-10-14 20:31 440 -> socket:[76495]
lrwx------ 1 root root 64 2013-10-14 20:31 441 -> socket:[76500]
lrwx------ 1 root root 64 2013-10-14 20:31 442 -> socket:[76505]
lrwx------ 1 root root 64 2013-10-14 20:31 443 -> socket:[76510]
lrwx------ 1 root root 64 2013-10-14 20:31 444 -> socket:[76515]
lrwx------ 1 root root 64 2013-10-14 20:31 445 -> socket:[76544]
lrwx------ 1 root root 64 2013-10-14 20:31 446 -> socket:[76566]
lrwx------ 1 root root 64 2013-10-14 20:31 447 -> socket:[76571]
lrwx------ 1 root root 64 2013-10-14 20:31 448 -> socket:[76576]
lrwx------ 1 root root 64 2013-10-14 20:31 449 -> socket:[76581]
lrwx------ 1 root root 64 2013-10-14 20:31 45 -> socket:[72794]
lrwx------ 1 root root 64 2013-10-14 20:31 450 -> socket:[76586]
lrwx------ 1 root root 64 2013-10-14 20:31 451 -> socket:[76592]
lrwx------ 1 root root 64 2013-10-14 20:31 452 -> socket:[76597]
lrwx------ 1 root root 64 2013-10-14 20:31 453 -> socket:[76602]
lrwx------ 1 root root 64 2013-10-14 20:31 454 -> socket:[76609]
lrwx------ 1 root root 64 2013-10-14 20:31 455 -> socket:[76614]
lrwx------ 1 root root 64 2013-10-14 20:31 456 -> socket:[76644]
lrwx------ 1 root root 64 2013-10-14 20:31 457 -> socket:[76649]
lrwx------ 1 root root 64 2013-10-14 20:31 458 -> socket:[76654]
lrwx------ 1 root root 64 2013-10-14 20:31 459 -> socket:[76659]
lrwx------ 1 root root 64 2013-10-14 20:31 46 -> socket:[72799]
lrwx------ 1 root root 64 2013-10-14 20:31 460 -> socket:[76664]
lrwx------ 1 root root 64 2013-10-14 20:31 461 -> socket:[76669]
lrwx------ 1 root root 64 2013-10-14 20:31 462 -> socket:[76674]
lrwx------ 1 root root 64 2013-10-14 20:31 463 -> socket:[76692]
lrwx------ 1 root root 64 2013-10-14 20:31 464 -> socket:[76705]
lrwx------ 1 root root 64 2013-10-14 20:31 465 -> socket:[76710]
lrwx------ 1 root root 64 2013-10-14 20:31 466 -> socket:[76715]
lrwx------ 1 root root 64 2013-10-14 20:31 467 -> socket:[76720]
lrwx------ 1 root root 64 2013-10-14 20:31 468 -> socket:[76725]
lrwx------ 1 root root 64 2013-10-14 20:31 469 -> socket:[76732]
lrwx------ 1 root root 64 2013-10-14 20:31 47 -> socket:[72805]
lrwx------ 1 root root 64 2013-10-14 20:31 470 -> socket:[76737]
lrwx------ 1 root root 64 2013-10-14 20:31 471 -> socket:[76742]
lrwx------ 1 root root 64 2013-10-14 20:31 472 -> socket:[76747]
lrwx------ 1 root root 64 2013-10-14 20:31 473 -> socket:[76752]
lrwx------ 1 root root 64 2013-10-14 20:31 474 -> socket:[76757]
lrwx------ 1 root root 64 2013-10-14 20:31 475 -> socket:[76763]
lrwx------ 1 root root 64 2013-10-14 20:31 476 -> socket:[76768]
lrwx------ 1 root root 64 2013-10-14 20:31 477 -> socket:[76773]
lrwx------ 1 root root 64 2013-10-14 20:31 478 -> socket:[76778]
lrwx------ 1 root root 64 2013-10-14 20:31 479 -> socket:[76783]
lrwx------ 1 root root 64 2013-10-14 20:31 48 -> socket:[72838]
lrwx------ 1 root root 64 2013-10-14 20:31 480 -> socket:[76788]
lrwx------ 1 root root 64 2013-10-14 20:31 481 -> socket:[76817]
lrwx------ 1 root root 64 2013-10-14 20:31 482 -> socket:[76822]
lrwx------ 1 root root 64 2013-10-14 20:31 483 -> socket:[76827]
lrwx------ 1 root root 64 2013-10-14 20:31 484 -> socket:[76834]
lrwx------ 1 root root 64 2013-10-14 20:31 485 -> socket:[76839]
lrwx------ 1 root root 64 2013-10-14 20:31 486 -> socket:[76844]
lrwx------ 1 root root 64 2013-10-14 20:31 487 -> socket:[76849]
lrwx------ 1 root root 64 2013-10-14 20:31 488 -> socket:[76855]
lrwx------ 1 root root 64 2013-10-14 20:31 489 -> socket:[76860]
lrwx------ 1 root root 64 2013-10-14 20:31 49 -> socket:[72845]
lrwx------ 1 root root 64 2013-10-14 20:31 490 -> socket:[76865]
lrwx------ 1 root root 64 2013-10-14 20:31 491 -> socket:[76870]
lrwx------ 1 root root 64 2013-10-14 20:31 492 -> socket:[76875]
lrwx------ 1 root root 64 2013-10-14 20:31 493 -> socket:[76880]
lrwx------ 1 root root 64 2013-10-14 20:31 494 -> socket:[76885]
lrwx------ 1 root root 64 2013-10-14 20:31 495 -> socket:[76890]
lrwx------ 1 root root 64 2013-10-14 20:31 496 -> socket:[76895]
lrwx------ 1 root root 64 2013-10-14 20:31 497 -> socket:[76900]
lrwx------ 1 root root 64 2013-10-14 20:31 498 -> socket:[76905]
lrwx------ 1 root root 64 2013-10-14 20:31 499 -> socket:[76924]
lrwx------ 1 root root 64 2013-10-14 20:31 5 -> socket:[5095]
lrwx------ 1 root root 64 2013-10-14 20:31 50 -> socket:[72874]
lrwx------ 1 root root 64 2013-10-14 20:31 500 -> socket:[76930]
lrwx------ 1 root root 64 2013-10-14 20:31 501 -> socket:[76935]
lrwx------ 1 root root 64 2013-10-14 20:31 502 -> socket:[76940]
lrwx------ 1 root root 64 2013-10-14 20:31 503 -> socket:[76945]
lrwx------ 1 root root 64 2013-10-14 20:31 504 -> socket:[76950]
lrwx------ 1 root root 64 2013-10-14 20:31 505 -> socket:[76955]
lrwx------ 1 root root 64 2013-10-14 20:31 506 -> socket:[76960]
lrwx------ 1 root root 64 2013-10-14 20:31 507 -> socket:[76965]
lrwx------ 1 root root 64 2013-10-14 20:31 508 -> socket:[76970]
lrwx------ 1 root root 64 2013-10-14 20:31 509 -> socket:[76975]
lrwx------ 1 root root 64 2013-10-14 20:31 51 -> socket:[72879]
lrwx------ 1 root root 64 2013-10-14 20:31 510 -> socket:[76980]
lrwx------ 1 root root 64 2013-10-14 20:31 511 -> socket:[76985]
lrwx------ 1 root root 64 2013-10-14 20:31 512 -> socket:[76991]
lrwx------ 1 root root 64 2013-10-14 20:31 513 -> socket:[76996]
lrwx------ 1 root root 64 2013-10-14 20:31 514 -> socket:[77003]
lrwx------ 1 root root 64 2013-10-14 20:31 515 -> socket:[77008]
lrwx------ 1 root root 64 2013-10-14 20:31 516 -> socket:[77013]
lrwx------ 1 root root 64 2013-10-14 20:31 517 -> socket:[77042]
lrwx------ 1 root root 64 2013-10-14 20:31 518 -> socket:[77047]
lrwx------ 1 root root 64 2013-10-14 20:31 519 -> socket:[77052]
lrwx------ 1 root root 64 2013-10-14 20:31 52 -> socket:[72884]
lrwx------ 1 root root 64 2013-10-14 20:31 520 -> socket:[77057]
lrwx------ 1 root root 64 2013-10-14 20:31 521 -> socket:[77062]
lrwx------ 1 root root 64 2013-10-14 20:31 522 -> socket:[77067]
lrwx------ 1 root root 64 2013-10-14 20:31 523 -> socket:[77101]
lrwx------ 1 root root 64 2013-10-14 20:31 524 -> socket:[77106]
lrwx------ 1 root root 64 2013-10-14 20:31 525 -> socket:[77111]
lrwx------ 1 root root 64 2013-10-14 20:31 526 -> socket:[77116]
lrwx------ 1 root root 64 2013-10-14 20:31 527 -> socket:[77121]
lrwx------ 1 root root 64 2013-10-14 20:31 528 -> socket:[77126]
lrwx------ 1 root root 64 2013-10-14 20:31 529 -> socket:[77133]
lrwx------ 1 root root 64 2013-10-14 20:31 53 -> socket:[72889]
lrwx------ 1 root root 64 2013-10-14 20:31 530 -> socket:[77138]
lrwx------ 1 root root 64 2013-10-14 20:31 531 -> socket:[77143]
lrwx------ 1 root root 64 2013-10-14 20:31 532 -> socket:[77148]
lrwx------ 1 root root 64 2013-10-14 20:31 533 -> socket:[77153]
lrwx------ 1 root root 64 2013-10-14 20:31 534 -> socket:[77158]
lrwx------ 1 root root 64 2013-10-14 20:31 535 -> socket:[77175]
lrwx------ 1 root root 64 2013-10-14 20:31 536 -> socket:[77198]
lrwx------ 1 root root 64 2013-10-14 20:31 537 -> socket:[77203]
lrwx------ 1 root root 64 2013-10-14 20:31 538 -> socket:[77208]
lrwx------ 1 root root 64 2013-10-14 20:31 539 -> socket:[77213]
lrwx------ 1 root root 64 2013-10-14 20:31 54 -> socket:[72894]
lrwx------ 1 root root 64 2013-10-14 20:31 540 -> socket:[77218]
lrwx------ 1 root root 64 2013-10-14 20:31 541 -> socket:[77223]
lrwx------ 1 root root 64 2013-10-14 20:31 542 -> socket:[77236]
lrwx------ 1 root root 64 2013-10-14 20:31 543 -> socket:[77241]
lrwx------ 1 root root 64 2013-10-14 20:31 544 -> socket:[77248]
lrwx------ 1 root root 64 2013-10-14 20:31 545 -> socket:[77253]
lrwx------ 1 root root 64 2013-10-14 20:31 546 -> socket:[77258]
lrwx------ 1 root root 64 2013-10-14 20:31 547 -> socket:[77263]
lrwx------ 1 root root 64 2013-10-14 20:31 548 -> socket:[77269]
lrwx------ 1 root root 64 2013-10-14 20:31 549 -> socket:[77274]
lrwx------ 1 root root 64 2013-10-14 20:31 55 -> socket:[72899]
lrwx------ 1 root root 64 2013-10-14 20:31 550 -> socket:[77279]
lrwx------ 1 root root 64 2013-10-14 20:31 551 -> socket:[77284]
lrwx------ 1 root root 64 2013-10-14 20:31 552 -> socket:[77313]
lrwx------ 1 root root 64 2013-10-14 20:31 553 -> socket:[77318]
lrwx------ 1 root root 64 2013-10-14 20:31 554 -> socket:[77323]
lrwx------ 1 root root 64 2013-10-14 20:31 555 -> socket:[77328]
lrwx------ 1 root root 64 2013-10-14 20:31 556 -> socket:[77333]
lrwx------ 1 root root 64 2013-10-14 20:31 557 -> socket:[77338]
lrwx------ 1 root root 64 2013-10-14 20:31 558 -> socket:[77343]
lrwx------ 1 root root 64 2013-10-14 20:31 559 -> socket:[77350]
lrwx------ 1 root root 64 2013-10-14 20:31 56 -> socket:[72929]
lrwx------ 1 root root 64 2013-10-14 20:31 560 -> socket:[77355]
lrwx------ 1 root root 64 2013-10-14 20:31 561 -> socket:[77361]
lrwx------ 1 root root 64 2013-10-14 20:31 562 -> socket:[77366]
lrwx------ 1 root root 64 2013-10-14 20:31 563 -> socket:[77371]
lrwx------ 1 root root 64 2013-10-14 20:31 564 -> socket:[77376]
lrwx------ 1 root root 64 2013-10-14 20:31 565 -> socket:[77381]
lrwx------ 1 root root 64 2013-10-14 20:31 566 -> socket:[77386]
lrwx------ 1 root root 64 2013-10-14 20:31 567 -> socket:[77391]
lrwx------ 1 root root 64 2013-10-14 20:31 568 -> socket:[77396]
lrwx------ 1 root root 64 2013-10-14 20:31 569 -> socket:[77401]
lrwx------ 1 root root 64 2013-10-14 20:31 57 -> socket:[72934]
lrwx------ 1 root root 64 2013-10-14 20:31 570 -> socket:[77418]
lrwx------ 1 root root 64 2013-10-14 20:31 571 -> socket:[77423]
lrwx------ 1 root root 64 2013-10-14 20:31 572 -> socket:[77428]
lrwx------ 1 root root 64 2013-10-14 20:31 573 -> socket:[77434]
lrwx------ 1 root root 64 2013-10-14 20:31 574 -> socket:[77441]
lrwx------ 1 root root 64 2013-10-14 20:31 575 -> socket:[77446]
lrwx------ 1 root root 64 2013-10-14 20:31 576 -> socket:[91225]
lrwx------ 1 root root 64 2013-10-14 20:31 577 -> socket:[91230]
lrwx------ 1 root root 64 2013-10-14 20:31 578 -> socket:[91235]
lrwx------ 1 root root 64 2013-10-14 20:31 579 -> socket:[91242]
lrwx------ 1 root root 64 2013-10-14 20:31 58 -> socket:[72939]
lrwx------ 1 root root 64 2013-10-14 20:31 580 -> socket:[91247]
lrwx------ 1 root root 64 2013-10-14 20:31 581 -> socket:[91253]
lrwx------ 1 root root 64 2013-10-14 20:31 582 -> socket:[91258]
lrwx------ 1 root root 64 2013-10-14 20:31 583 -> socket:[91263]
lrwx------ 1 root root 64 2013-10-14 20:31 584 -> socket:[91268]
lrwx------ 1 root root 64 2013-10-14 20:31 585 -> socket:[91273]
lrwx------ 1 root root 64 2013-10-14 20:31 586 -> socket:[91278]
lrwx------ 1 root root 64 2013-10-14 20:31 587 -> socket:[91283]
lrwx------ 1 root root 64 2013-10-14 20:31 588 -> socket:[91288]
lrwx------ 1 root root 64 2013-10-14 20:31 589 -> socket:[91293]
lrwx------ 1 root root 64 2013-10-14 20:31 59 -> socket:[72945]
lrwx------ 1 root root 64 2013-10-14 20:31 590 -> socket:[91298]
lrwx------ 1 root root 64 2013-10-14 20:31 591 -> socket:[91328]
lrwx------ 1 root root 64 2013-10-14 20:31 592 -> socket:[91357]
lrwx------ 1 root root 64 2013-10-14 20:31 593 -> socket:[91376]
lrwx------ 1 root root 64 2013-10-14 20:31 594 -> socket:[91387]
lrwx------ 1 root root 64 2013-10-14 20:31 595 -> socket:[91392]
lrwx------ 1 root root 64 2013-10-14 20:31 596 -> socket:[91397]
lrwx------ 1 root root 64 2013-10-14 20:31 597 -> socket:[91402]
lrwx------ 1 root root 64 2013-10-14 20:31 598 -> socket:[91407]
lrwx------ 1 root root 64 2013-10-14 20:31 599 -> socket:[91412]
lr-x------ 1 root root 64 2013-10-14 20:31 6 -> pipe:[4796]
lrwx------ 1 root root 64 2013-10-14 20:31 60 -> socket:[72950]
lrwx------ 1 root root 64 2013-10-14 20:31 600 -> socket:[91417]
lrwx------ 1 root root 64 2013-10-14 20:31 601 -> socket:[91422]
lrwx------ 1 root root 64 2013-10-14 20:31 602 -> socket:[91427]
lrwx------ 1 root root 64 2013-10-14 20:31 603 -> socket:[91432]
lrwx------ 1 root root 64 2013-10-14 20:31 604 -> socket:[91437]
lrwx------ 1 root root 64 2013-10-14 20:31 605 -> socket:[91443]
lrwx------ 1 root root 64 2013-10-14 20:31 606 -> socket:[91448]
lrwx------ 1 root root 64 2013-10-14 20:31 607 -> socket:[91453]
lrwx------ 1 root root 64 2013-10-14 20:31 608 -> socket:[91458]
lrwx------ 1 root root 64 2013-10-14 20:31 609 -> socket:[91465]
lrwx------ 1 root root 64 2013-10-14 20:31 61 -> socket:[72955]
lrwx------ 1 root root 64 2013-10-14 20:31 610 -> socket:[91482]
lrwx------ 1 root root 64 2013-10-14 20:31 611 -> socket:[91487]
lrwx------ 1 root root 64 2013-10-14 20:31 612 -> socket:[91492]
lrwx------ 1 root root 64 2013-10-14 20:31 613 -> socket:[91497]
lrwx------ 1 root root 64 2013-10-14 20:31 614 -> socket:[91502]
lrwx------ 1 root root 64 2013-10-14 20:31 615 -> socket:[91507]
lrwx------ 1 root root 64 2013-10-14 20:31 616 -> socket:[91512]
lrwx------ 1 root root 64 2013-10-14 20:31 617 -> socket:[91526]
lrwx------ 1 root root 64 2013-10-14 20:31 618 -> socket:[91531]
lrwx------ 1 root root 64 2013-10-14 20:31 619 -> socket:[91536]
lrwx------ 1 root root 64 2013-10-14 20:31 62 -> socket:[72960]
lrwx------ 1 root root 64 2013-10-14 20:31 620 -> socket:[91541]
lrwx------ 1 root root 64 2013-10-14 20:31 621 -> socket:[91546]
lrwx------ 1 root root 64 2013-10-14 20:31 622 -> socket:[91551]
lrwx------ 1 root root 64 2013-10-14 20:31 623 -> socket:[91556]
lrwx------ 1 root root 64 2013-10-14 20:31 624 -> socket:[91563]
lrwx------ 1 root root 64 2013-10-14 20:31 625 -> socket:[91568]
lrwx------ 1 root root 64 2013-10-14 20:31 626 -> socket:[91573]
lrwx------ 1 root root 64 2013-10-14 20:31 627 -> socket:[91578]
lrwx------ 1 root root 64 2013-10-14 20:31 628 -> socket:[91607]
lrwx------ 1 root root 64 2013-10-14 20:31 629 -> socket:[91613]
lrwx------ 1 root root 64 2013-10-14 20:31 63 -> socket:[72965]
lrwx------ 1 root root 64 2013-10-14 20:31 630 -> socket:[91618]
lrwx------ 1 root root 64 2013-10-14 20:31 631 -> socket:[91623]
lrwx------ 1 root root 64 2013-10-14 20:31 632 -> socket:[91628]
lrwx------ 1 root root 64 2013-10-14 20:31 633 -> socket:[91633]
lrwx------ 1 root root 64 2013-10-14 20:31 634 -> socket:[91638]
lrwx------ 1 root root 64 2013-10-14 20:31 635 -> socket:[91643]
lrwx------ 1 root root 64 2013-10-14 20:31 636 -> socket:[91648]
lrwx------ 1 root root 64 2013-10-14 20:31 637 -> socket:[91653]
lrwx------ 1 root root 64 2013-10-14 20:31 638 -> socket:[91658]
lrwx------ 1 root root 64 2013-10-14 20:31 639 -> socket:[91665]
lrwx------ 1 root root 64 2013-10-14 20:31 64 -> socket:[72972]
lrwx------ 1 root root 64 2013-10-14 20:31 640 -> socket:[91670]
lrwx------ 1 root root 64 2013-10-14 20:31 641 -> socket:[91675]
lrwx------ 1 root root 64 2013-10-14 20:31 642 -> socket:[91681]
lrwx------ 1 root root 64 2013-10-14 20:31 643 -> socket:[91686]
lrwx------ 1 root root 64 2013-10-14 20:31 644 -> socket:[91691]
lrwx------ 1 root root 64 2013-10-14 20:31 645 -> socket:[91696]
lrwx------ 1 root root 64 2013-10-14 20:31 646 -> socket:[91713]
lrwx------ 1 root root 64 2013-10-14 20:31 647 -> socket:[91718]
lrwx------ 1 root root 64 2013-10-14 20:31 648 -> socket:[91723]
lrwx------ 1 root root 64 2013-10-14 20:31 649 -> socket:[91728]
lrwx------ 1 root root 64 2013-10-14 20:31 65 -> socket:[72977]
lrwx------ 1 root root 64 2013-10-14 20:31 650 -> socket:[91733]
lrwx------ 1 root root 64 2013-10-14 20:31 651 -> socket:[91738]
lrwx------ 1 root root 64 2013-10-14 20:31 652 -> socket:[91743]
lrwx------ 1 root root 64 2013-10-14 20:31 653 -> socket:[91748]
lrwx------ 1 root root 64 2013-10-14 20:31 654 -> socket:[91756]
lrwx------ 1 root root 64 2013-10-14 20:31 655 -> socket:[91761]
lrwx------ 1 root root 64 2013-10-14 20:31 656 -> socket:[91766]
lrwx------ 1 root root 64 2013-10-14 20:31 657 -> socket:[91771]
lrwx------ 1 root root 64 2013-10-14 20:31 658 -> socket:[91776]
lrwx------ 1 root root 64 2013-10-14 20:31 659 -> socket:[91781]
lrwx------ 1 root root 64 2013-10-14 20:31 66 -> socket:[72982]
lrwx------ 1 root root 64 2013-10-14 20:31 660 -> socket:[91786]
lrwx------ 1 root root 64 2013-10-14 20:31 661 -> socket:[91791]
lrwx------ 1 root root 64 2013-10-14 20:31 662 -> socket:[91796]
lrwx------ 1 root root 64 2013-10-14 20:31 663 -> socket:[91801]
lrwx------ 1 root root 64 2013-10-14 20:31 664 -> socket:[91830]
lrwx------ 1 root root 64 2013-10-14 20:31 665 -> socket:[91835]
lrwx------ 1 root root 64 2013-10-14 20:31 666 -> socket:[91841]
lrwx------ 1 root root 64 2013-10-14 20:31 667 -> socket:[91846]
lrwx------ 1 root root 64 2013-10-14 20:31 668 -> socket:[91851]
lrwx------ 1 root root 64 2013-10-14 20:31 669 -> socket:[91858]
lrwx------ 1 root root 64 2013-10-14 20:31 67 -> socket:[72987]
lrwx------ 1 root root 64 2013-10-14 20:31 670 -> socket:[91863]
lrwx------ 1 root root 64 2013-10-14 20:31 671 -> socket:[91896]
lrwx------ 1 root root 64 2013-10-14 20:31 672 -> socket:[91901]
lrwx------ 1 root root 64 2013-10-14 20:31 673 -> socket:[91906]
lrwx------ 1 root root 64 2013-10-14 20:31 674 -> socket:[91911]
lrwx------ 1 root root 64 2013-10-14 20:31 675 -> socket:[91916]
lrwx------ 1 root root 64 2013-10-14 20:31 676 -> socket:[91921]
lrwx------ 1 root root 64 2013-10-14 20:31 677 -> socket:[91926]
lrwx------ 1 root root 64 2013-10-14 20:31 678 -> socket:[91931]
lrwx------ 1 root root 64 2013-10-14 20:31 679 -> socket:[91937]
lrwx------ 1 root root 64 2013-10-14 20:31 68 -> socket:[73004]
lrwx------ 1 root root 64 2013-10-14 20:31 680 -> socket:[91942]
lrwx------ 1 root root 64 2013-10-14 20:31 681 -> socket:[91947]
lrwx------ 1 root root 64 2013-10-14 20:31 682 -> socket:[91964]
lrwx------ 1 root root 64 2013-10-14 20:31 683 -> socket:[91983]
lrwx------ 1 root root 64 2013-10-14 20:31 684 -> socket:[91993]
lrwx------ 1 root root 64 2013-10-14 20:31 685 -> socket:[91998]
lrwx------ 1 root root 64 2013-10-14 20:31 686 -> socket:[92003]
lrwx------ 1 root root 64 2013-10-14 20:31 687 -> socket:[92008]
lrwx------ 1 root root 64 2013-10-14 20:31 688 -> socket:[92013]
lrwx------ 1 root root 64 2013-10-14 20:31 689 -> socket:[92018]
lrwx------ 1 root root 64 2013-10-14 20:31 69 -> socket:[73009]
lrwx------ 1 root root 64 2013-10-14 20:31 690 -> socket:[92023]
lrwx------ 1 root root 64 2013-10-14 20:31 691 -> socket:[92029]
lrwx------ 1 root root 64 2013-10-14 20:31 692 -> socket:[92034]
lrwx------ 1 root root 64 2013-10-14 20:31 693 -> socket:[92039]
lrwx------ 1 root root 64 2013-10-14 20:31 694 -> socket:[92044]
lrwx------ 1 root root 64 2013-10-14 20:31 695 -> socket:[92057]
lrwx------ 1 root root 64 2013-10-14 20:31 696 -> socket:[92082]
lrwx------ 1 root root 64 2013-10-14 20:31 697 -> socket:[92087]
lrwx------ 1 root root 64 2013-10-14 20:31 698 -> socket:[92092]
lrwx------ 1 root root 64 2013-10-14 20:31 699 -> socket:[92099]
l-wx------ 1 root root 64 2013-10-14 20:31 7 -> pipe:[4796]
lrwx------ 1 root root 64 2013-10-14 20:31 70 -> socket:[73014]
lrwx------ 1 root root 64 2013-10-14 20:31 700 -> socket:[92128]
lrwx------ 1 root root 64 2013-10-14 20:31 701 -> socket:[92133]
lrwx------ 1 root root 64 2013-10-14 20:31 702 -> socket:[92138]
lrwx------ 1 root root 64 2013-10-14 20:31 703 -> socket:[92144]
lrwx------ 1 root root 64 2013-10-14 20:31 704 -> socket:[92149]
lrwx------ 1 root root 64 2013-10-14 20:31 705 -> socket:[92154]
lrwx------ 1 root root 64 2013-10-14 20:31 706 -> socket:[92159]
lrwx------ 1 root root 64 2013-10-14 20:31 707 -> socket:[92164]
lrwx------ 1 root root 64 2013-10-14 20:31 708 -> socket:[92169]
lrwx------ 1 root root 64 2013-10-14 20:31 709 -> socket:[92174]
lrwx------ 1 root root 64 2013-10-14 20:31 71 -> socket:[73020]
lrwx------ 1 root root 64 2013-10-14 20:31 710 -> socket:[92179]
lrwx------ 1 root root 64 2013-10-14 20:31 711 -> socket:[92184]
lrwx------ 1 root root 64 2013-10-14 20:31 712 -> socket:[92189]
lrwx------ 1 root root 64 2013-10-14 20:31 713 -> socket:[92194]
lrwx------ 1 root root 64 2013-10-14 20:31 714 -> socket:[92201]
lrwx------ 1 root root 64 2013-10-14 20:31 715 -> socket:[92207]
lrwx------ 1 root root 64 2013-10-14 20:31 716 -> socket:[92212]
lrwx------ 1 root root 64 2013-10-14 20:31 717 -> socket:[92217]
lrwx------ 1 root root 64 2013-10-14 20:31 718 -> socket:[92234]
lrwx------ 1 root root 64 2013-10-14 20:31 719 -> socket:[92239]
lrwx------ 1 root root 64 2013-10-14 20:31 72 -> socket:[73050]
lrwx------ 1 root root 64 2013-10-14 20:31 720 -> socket:[92244]
lrwx------ 1 root root 64 2013-10-14 20:31 721 -> socket:[92249]
lrwx------ 1 root root 64 2013-10-14 20:31 722 -> socket:[92254]
lrwx------ 1 root root 64 2013-10-14 20:31 723 -> socket:[92259]
lrwx------ 1 root root 64 2013-10-14 20:31 724 -> socket:[92264]
lrwx------ 1 root root 64 2013-10-14 20:31 725 -> socket:[92269]
lrwx------ 1 root root 64 2013-10-14 20:31 726 -> socket:[92274]
lrwx------ 1 root root 64 2013-10-14 20:31 727 -> socket:[92280]
lrwx------ 1 root root 64 2013-10-14 20:31 728 -> socket:[92285]
lrwx------ 1 root root 64 2013-10-14 20:31 729 -> socket:[92292]
lrwx------ 1 root root 64 2013-10-14 20:31 73 -> socket:[73055]
lrwx------ 1 root root 64 2013-10-14 20:31 730 -> socket:[92297]
lrwx------ 1 root root 64 2013-10-14 20:31 731 -> socket:[92302]
lrwx------ 1 root root 64 2013-10-14 20:31 732 -> socket:[92307]
lrwx------ 1 root root 64 2013-10-14 20:31 733 -> socket:[92312]
lrwx------ 1 root root 64 2013-10-14 20:31 734 -> socket:[92317]
lrwx------ 1 root root 64 2013-10-14 20:31 735 -> socket:[92322]
lrwx------ 1 root root 64 2013-10-14 20:31 736 -> socket:[92351]
lrwx------ 1 root root 64 2013-10-14 20:31 737 -> socket:[92356]
lrwx------ 1 root root 64 2013-10-14 20:31 738 -> socket:[92361]
lrwx------ 1 root root 64 2013-10-14 20:31 739 -> socket:[92367]
lrwx------ 1 root root 64 2013-10-14 20:31 74 -> socket:[73060]
lrwx------ 1 root root 64 2013-10-14 20:31 740 -> socket:[92372]
lrwx------ 1 root root 64 2013-10-14 20:31 741 -> socket:[92377]
lrwx------ 1 root root 64 2013-10-14 20:31 742 -> socket:[92382]
lrwx------ 1 root root 64 2013-10-14 20:31 743 -> socket:[92387]
lrwx------ 1 root root 64 2013-10-14 20:31 744 -> socket:[92394]
lrwx------ 1 root root 64 2013-10-14 20:31 745 -> socket:[92399]
lrwx------ 1 root root 64 2013-10-14 20:31 746 -> socket:[92404]
lrwx------ 1 root root 64 2013-10-14 20:31 747 -> socket:[92409]
lrwx------ 1 root root 64 2013-10-14 20:31 748 -> socket:[92414]
lrwx------ 1 root root 64 2013-10-14 20:31 749 -> socket:[92419]
lrwx------ 1 root root 64 2013-10-14 20:31 75 -> socket:[73073]
lrwx------ 1 root root 64 2013-10-14 20:31 750 -> socket:[92424]
lrwx------ 1 root root 64 2013-10-14 20:31 751 -> socket:[92430]
lrwx------ 1 root root 64 2013-10-14 20:31 752 -> socket:[92435]
lrwx------ 1 root root 64 2013-10-14 20:31 753 -> socket:[92440]
lrwx------ 1 root root 64 2013-10-14 20:31 754 -> socket:[92457]
lrwx------ 1 root root 64 2013-10-14 20:31 755 -> socket:[92462]
lrwx------ 1 root root 64 2013-10-14 20:31 756 -> socket:[92467]
lrwx------ 1 root root 64 2013-10-14 20:31 757 -> socket:[92472]
lrwx------ 1 root root 64 2013-10-14 20:31 758 -> socket:[92477]
lrwx------ 1 root root 64 2013-10-14 20:31 759 -> socket:[92484]
lrwx------ 1 root root 64 2013-10-14 20:31 76 -> socket:[73078]
lrwx------ 1 root root 64 2013-10-14 20:31 760 -> socket:[92489]
lrwx------ 1 root root 64 2013-10-14 20:31 761 -> socket:[92494]
lrwx------ 1 root root 64 2013-10-14 20:31 762 -> socket:[92499]
lrwx------ 1 root root 64 2013-10-14 20:31 763 -> socket:[92505]
lrwx------ 1 root root 64 2013-10-14 20:31 764 -> socket:[92510]
lrwx------ 1 root root 64 2013-10-14 20:31 765 -> socket:[92515]
lrwx------ 1 root root 64 2013-10-14 20:31 766 -> socket:[92520]
lrwx------ 1 root root 64 2013-10-14 20:31 767 -> socket:[92525]
lrwx------ 1 root root 64 2013-10-14 20:31 768 -> socket:[92558]
lrwx------ 1 root root 64 2013-10-14 20:31 769 -> socket:[92563]
lrwx------ 1 root root 64 2013-10-14 20:31 77 -> socket:[73083]
lrwx------ 1 root root 64 2013-10-14 20:31 770 -> socket:[92568]
lrwx------ 1 root root 64 2013-10-14 20:31 771 -> socket:[92598]
lrwx------ 1 root root 64 2013-10-14 20:31 772 -> socket:[92627]
lrwx------ 1 root root 64 2013-10-14 20:31 773 -> socket:[92657]
lrwx------ 1 root root 64 2013-10-14 20:31 774 -> socket:[92664]
lrwx------ 1 root root 64 2013-10-14 20:31 775 -> socket:[92670]
lrwx------ 1 root root 64 2013-10-14 20:31 776 -> socket:[92675]
lrwx------ 1 root root 64 2013-10-14 20:31 777 -> socket:[92680]
lrwx------ 1 root root 64 2013-10-14 20:31 778 -> socket:[92685]
lrwx------ 1 root root 64 2013-10-14 20:31 779 -> socket:[92690]
lrwx------ 1 root root 64 2013-10-14 20:31 78 -> socket:[73088]
lrwx------ 1 root root 64 2013-10-14 20:31 780 -> socket:[92695]
lrwx------ 1 root root 64 2013-10-14 20:31 781 -> socket:[92700]
lrwx------ 1 root root 64 2013-10-14 20:31 782 -> socket:[96885]
lrwx------ 1 root root 64 2013-10-14 20:31 783 -> socket:[96890]
lrwx------ 1 root root 64 2013-10-14 20:31 784 -> socket:[96895]
lrwx------ 1 root root 64 2013-10-14 20:31 785 -> socket:[96927]
lrwx------ 1 root root 64 2013-10-14 20:31 786 -> socket:[96932]
lrwx------ 1 root root 64 2013-10-14 20:31 787 -> socket:[96937]
lrwx------ 1 root root 64 2013-10-14 20:31 788 -> socket:[96968]
lrwx------ 1 root root 64 2013-10-14 20:31 789 -> socket:[96973]
lrwx------ 1 root root 64 2013-10-14 20:31 79 -> socket:[73095]
lrwx------ 1 root root 64 2013-10-14 20:31 790 -> socket:[96978]
lrwx------ 1 root root 64 2013-10-14 20:31 791 -> socket:[97008]
lrwx------ 1 root root 64 2013-10-14 20:31 792 -> socket:[97013]
lrwx------ 1 root root 64 2013-10-14 20:31 793 -> socket:[97018]
lrwx------ 1 root root 64 2013-10-14 20:31 794 -> socket:[97023]
lrwx------ 1 root root 64 2013-10-14 20:31 795 -> socket:[97053]
lrwx------ 1 root root 64 2013-10-14 20:31 796 -> socket:[97058]
lrwx------ 1 root root 64 2013-10-14 20:31 797 -> socket:[97075]
lrwx------ 1 root root 64 2013-10-14 20:31 798 -> socket:[97105]
lrwx------ 1 root root 64 2013-10-14 20:31 799 -> socket:[97110]
lrwx------ 1 root root 64 2013-10-14 20:31 8 -> socket:[4797]
lrwx------ 1 root root 64 2013-10-14 20:31 80 -> socket:[73100]
lrwx------ 1 root root 64 2013-10-14 20:31 800 -> socket:[97117]
lrwx------ 1 root root 64 2013-10-14 20:31 801 -> socket:[97123]
lrwx------ 1 root root 64 2013-10-14 20:31 802 -> socket:[97153]
lrwx------ 1 root root 64 2013-10-14 20:31 803 -> socket:[97158]
lrwx------ 1 root root 64 2013-10-14 20:31 804 -> socket:[97163]
lrwx------ 1 root root 64 2013-10-14 20:31 805 -> socket:[97168]
lrwx------ 1 root root 64 2013-10-14 20:31 806 -> socket:[97198]
lrwx------ 1 root root 64 2013-10-14 20:31 807 -> socket:[97203]
lrwx------ 1 root root 64 2013-10-14 20:31 808 -> socket:[97208]
lrwx------ 1 root root 64 2013-10-14 20:31 809 -> socket:[97213]
lrwx------ 1 root root 64 2013-10-14 20:31 81 -> socket:[73105]
lrwx------ 1 root root 64 2013-10-14 20:31 810 -> socket:[97246]
lrwx------ 1 root root 64 2013-10-14 20:31 811 -> socket:[97251]
lrwx------ 1 root root 64 2013-10-14 20:31 812 -> socket:[97256]
lrwx------ 1 root root 64 2013-10-14 20:31 813 -> socket:[97262]
lrwx------ 1 root root 64 2013-10-14 20:31 814 -> socket:[97292]
lrwx------ 1 root root 64 2013-10-14 20:31 815 -> socket:[97323]
lrwx------ 1 root root 64 2013-10-14 20:31 816 -> socket:[97328]
lrwx------ 1 root root 64 2013-10-14 20:31 817 -> socket:[97333]
lrwx------ 1 root root 64 2013-10-14 20:31 818 -> socket:[97338]
lrwx------ 1 root root 64 2013-10-14 20:31 819 -> socket:[97343]
lrwx------ 1 root root 64 2013-10-14 20:31 82 -> socket:[73110]
lrwx------ 1 root root 64 2013-10-14 20:31 820 -> socket:[97348]
lrwx------ 1 root root 64 2013-10-14 20:31 821 -> socket:[97381]
lrwx------ 1 root root 64 2013-10-14 20:31 822 -> socket:[97411]
lrwx------ 1 root root 64 2013-10-14 20:31 823 -> socket:[97424]
lrwx------ 1 root root 64 2013-10-14 20:31 824 -> socket:[97429]
lrwx------ 1 root root 64 2013-10-14 20:31 825 -> socket:[97435]
lrwx------ 1 root root 64 2013-10-14 20:31 826 -> socket:[97440]
lrwx------ 1 root root 64 2013-10-14 20:31 827 -> socket:[97445]
lrwx------ 1 root root 64 2013-10-14 20:31 828 -> socket:[97450]
lrwx------ 1 root root 64 2013-10-14 20:31 829 -> socket:[97455]
lrwx------ 1 root root 64 2013-10-14 20:31 83 -> socket:[73116]
lrwx------ 1 root root 64 2013-10-14 20:31 830 -> socket:[97462]
lrwx------ 1 root root 64 2013-10-14 20:31 831 -> socket:[97467]
lrwx------ 1 root root 64 2013-10-14 20:31 832 -> socket:[97472]
lrwx------ 1 root root 64 2013-10-14 20:31 833 -> socket:[97502]
lrwx------ 1 root root 64 2013-10-14 20:31 834 -> socket:[97511]
lrwx------ 1 root root 64 2013-10-14 20:31 835 -> socket:[97516]
lrwx------ 1 root root 64 2013-10-14 20:31 836 -> socket:[97521]
lrwx------ 1 root root 64 2013-10-14 20:31 837 -> socket:[97526]
lrwx------ 1 root root 64 2013-10-14 20:31 838 -> socket:[97557]
lrwx------ 1 root root 64 2013-10-14 20:31 839 -> socket:[97562]
lrwx------ 1 root root 64 2013-10-14 20:31 84 -> socket:[73121]
lrwx------ 1 root root 64 2013-10-14 20:31 840 -> socket:[97567]
lrwx------ 1 root root 64 2013-10-14 20:31 841 -> socket:[97572]
lrwx------ 1 root root 64 2013-10-14 20:31 842 -> socket:[97577]
lrwx------ 1 root root 64 2013-10-14 20:31 843 -> socket:[97582]
lrwx------ 1 root root 64 2013-10-14 20:31 844 -> socket:[97587]
lrwx------ 1 root root 64 2013-10-14 20:31 845 -> socket:[97594]
lrwx------ 1 root root 64 2013-10-14 20:31 846 -> socket:[97599]
lrwx------ 1 root root 64 2013-10-14 20:31 847 -> socket:[97624]
lrwx------ 1 root root 64 2013-10-14 20:31 848 -> socket:[97629]
lrwx------ 1 root root 64 2013-10-14 20:31 849 -> socket:[97634]
lrwx------ 1 root root 64 2013-10-14 20:31 85 -> socket:[73150]
lrwx------ 1 root root 64 2013-10-14 20:31 850 -> socket:[97640]
lrwx------ 1 root root 64 2013-10-14 20:31 851 -> socket:[97669]
lrwx------ 1 root root 64 2013-10-14 20:31 852 -> socket:[97674]
lrwx------ 1 root root 64 2013-10-14 20:31 853 -> socket:[97679]
lrwx------ 1 root root 64 2013-10-14 20:31 854 -> socket:[97684]
lrwx------ 1 root root 64 2013-10-14 20:31 855 -> socket:[97689]
lrwx------ 1 root root 64 2013-10-14 20:31 856 -> socket:[97694]
lrwx------ 1 root root 64 2013-10-14 20:31 857 -> socket:[97699]
lrwx------ 1 root root 64 2013-10-14 20:31 858 -> socket:[97704]
lrwx------ 1 root root 64 2013-10-14 20:31 859 -> socket:[97709]
lrwx------ 1 root root 64 2013-10-14 20:31 86 -> socket:[73155]
lrwx------ 1 root root 64 2013-10-14 20:31 860 -> socket:[97716]
lrwx------ 1 root root 64 2013-10-14 20:31 861 -> socket:[97721]
lrwx------ 1 root root 64 2013-10-14 20:31 862 -> socket:[97726]
lrwx------ 1 root root 64 2013-10-14 20:31 863 -> socket:[97732]
lrwx------ 1 root root 64 2013-10-14 20:31 864 -> socket:[97737]
lrwx------ 1 root root 64 2013-10-14 20:31 865 -> socket:[97742]
lrwx------ 1 root root 64 2013-10-14 20:31 866 -> socket:[97747]
lrwx------ 1 root root 64 2013-10-14 20:31 867 -> socket:[97752]
lrwx------ 1 root root 64 2013-10-14 20:31 868 -> socket:[97757]
lrwx------ 1 root root 64 2013-10-14 20:31 869 -> socket:[97774]
lrwx------ 1 root root 64 2013-10-14 20:31 87 -> socket:[73177]
lrwx------ 1 root root 64 2013-10-14 20:31 870 -> socket:[97807]
lrwx------ 1 root root 64 2013-10-14 20:31 871 -> socket:[97812]
lrwx------ 1 root root 64 2013-10-14 20:31 872 -> socket:[97817]
lrwx------ 1 root root 64 2013-10-14 20:31 873 -> socket:[97822]
lrwx------ 1 root root 64 2013-10-14 20:31 874 -> socket:[97827]
lrwx------ 1 root root 64 2013-10-14 20:31 875 -> socket:[97835]
lrwx------ 1 root root 64 2013-10-14 20:31 876 -> socket:[97840]
lrwx------ 1 root root 64 2013-10-14 20:31 877 -> socket:[97845]
lrwx------ 1 root root 64 2013-10-14 20:31 878 -> socket:[97850]
lrwx------ 1 root root 64 2013-10-14 20:31 879 -> socket:[97855]
lrwx------ 1 root root 64 2013-10-14 20:31 88 -> socket:[73182]
lrwx------ 1 root root 64 2013-10-14 20:31 880 -> socket:[97860]
lrwx------ 1 root root 64 2013-10-14 20:31 881 -> socket:[97865]
lrwx------ 1 root root 64 2013-10-14 20:31 882 -> socket:[97870]
lrwx------ 1 root root 64 2013-10-14 20:31 883 -> socket:[97875]
lrwx------ 1 root root 64 2013-10-14 20:31 884 -> socket:[97880]
lrwx------ 1 root root 64 2013-10-14 20:31 885 -> socket:[97885]
lrwx------ 1 root root 64 2013-10-14 20:31 886 -> socket:[97903]
lrwx------ 1 root root 64 2013-10-14 20:31 887 -> socket:[97920]
lrwx------ 1 root root 64 2013-10-14 20:31 888 -> socket:[97925]
lrwx------ 1 root root 64 2013-10-14 20:31 889 -> socket:[97930]
lrwx------ 1 root root 64 2013-10-14 20:31 89 -> socket:[73187]
lrwx------ 1 root root 64 2013-10-14 20:31 890 -> socket:[97937]
lrwx------ 1 root root 64 2013-10-14 20:31 891 -> socket:[97942]
lrwx------ 1 root root 64 2013-10-14 20:31 892 -> socket:[97947]
lrwx------ 1 root root 64 2013-10-14 20:31 893 -> socket:[97952]
lrwx------ 1 root root 64 2013-10-14 20:31 894 -> socket:[97957]
lrwx------ 1 root root 64 2013-10-14 20:31 895 -> socket:[97962]
lrwx------ 1 root root 64 2013-10-14 20:31 896 -> socket:[97967]
lrwx------ 1 root root 64 2013-10-14 20:31 897 -> socket:[97972]
lrwx------ 1 root root 64 2013-10-14 20:31 898 -> socket:[97977]
lrwx------ 1 root root 64 2013-10-14 20:31 899 -> socket:[97983]
l-wx------ 1 root root 64 2013-10-14 20:31 9 -> /var/log/upnp-av.log
lrwx------ 1 root root 64 2013-10-14 20:31 90 -> socket:[73192]
lrwx------ 1 root root 64 2013-10-14 20:31 900 -> socket:[97988]
lrwx------ 1 root root 64 2013-10-14 20:31 901 -> socket:[98001]
lrwx------ 1 root root 64 2013-10-14 20:31 902 -> socket:[98006]
lrwx------ 1 root root 64 2013-10-14 20:31 903 -> socket:[98011]
lrwx------ 1 root root 64 2013-10-14 20:31 904 -> socket:[98028]
lrwx------ 1 root root 64 2013-10-14 20:31 905 -> socket:[98035]
lrwx------ 1 root root 64 2013-10-14 20:31 906 -> socket:[98040]
lrwx------ 1 root root 64 2013-10-14 20:31 907 -> socket:[98045]
lrwx------ 1 root root 64 2013-10-14 20:31 908 -> socket:[98050]
lrwx------ 1 root root 64 2013-10-14 20:31 909 -> socket:[98055]
lrwx------ 1 root root 64 2013-10-14 20:31 91 -> socket:[73197]
lrwx------ 1 root root 64 2013-10-14 20:31 910 -> socket:[98060]
lrwx------ 1 root root 64 2013-10-14 20:31 911 -> socket:[98066]
lrwx------ 1 root root 64 2013-10-14 20:31 912 -> socket:[98071]
lrwx------ 1 root root 64 2013-10-14 20:31 913 -> socket:[98076]
lrwx------ 1 root root 64 2013-10-14 20:31 914 -> socket:[98081]
lrwx------ 1 root root 64 2013-10-14 20:31 915 -> socket:[98086]
lrwx------ 1 root root 64 2013-10-14 20:31 916 -> socket:[98091]
lrwx------ 1 root root 64 2013-10-14 20:31 917 -> socket:[98096]
lrwx------ 1 root root 64 2013-10-14 20:31 918 -> socket:[98101]
lrwx------ 1 root root 64 2013-10-14 20:31 919 -> socket:[98106]
lrwx------ 1 root root 64 2013-10-14 20:31 92 -> socket:[73202]
lrwx------ 1 root root 64 2013-10-14 20:31 920 -> socket:[98113]
lrwx------ 1 root root 64 2013-10-14 20:31 921 -> socket:[98118]
lrwx------ 1 root root 64 2013-10-14 20:31 922 -> socket:[98147]
lrwx------ 1 root root 64 2013-10-14 20:31 923 -> socket:[98166]
lrwx------ 1 root root 64 2013-10-14 20:31 924 -> socket:[98175]
lrwx------ 1 root root 64 2013-10-14 20:31 925 -> socket:[98180]
lrwx------ 1 root root 64 2013-10-14 20:31 926 -> socket:[98185]
lrwx------ 1 root root 64 2013-10-14 20:31 927 -> socket:[98190]
lrwx------ 1 root root 64 2013-10-14 20:31 928 -> socket:[98195]
lrwx------ 1 root root 64 2013-10-14 20:31 929 -> socket:[98200]
lrwx------ 1 root root 64 2013-10-14 20:31 93 -> socket:[73207]
lrwx------ 1 root root 64 2013-10-14 20:31 930 -> socket:[98205]
lrwx------ 1 root root 64 2013-10-14 20:31 931 -> socket:[98210]
lrwx------ 1 root root 64 2013-10-14 20:31 932 -> socket:[98215]
lrwx------ 1 root root 64 2013-10-14 20:31 933 -> socket:[98220]
lrwx------ 1 root root 64 2013-10-14 20:31 934 -> socket:[98250]
lrwx------ 1 root root 64 2013-10-14 20:31 935 -> socket:[98257]
lrwx------ 1 root root 64 2013-10-14 20:31 936 -> socket:[98263]
lrwx------ 1 root root 64 2013-10-14 20:31 937 -> socket:[98268]
lrwx------ 1 root root 64 2013-10-14 20:31 938 -> socket:[98273]
lrwx------ 1 root root 64 2013-10-14 20:31 939 -> socket:[98278]
lrwx------ 1 root root 64 2013-10-14 20:31 94 -> socket:[73214]
lrwx------ 1 root root 64 2013-10-14 20:31 940 -> socket:[98295]
lrwx------ 1 root root 64 2013-10-14 20:31 941 -> socket:[98300]
lrwx------ 1 root root 64 2013-10-14 20:31 942 -> socket:[98305]
lrwx------ 1 root root 64 2013-10-14 20:31 943 -> socket:[98310]
lrwx------ 1 root root 64 2013-10-14 20:31 944 -> socket:[98315]
lrwx------ 1 root root 64 2013-10-14 20:31 945 -> socket:[98320]
lrwx------ 1 root root 64 2013-10-14 20:31 946 -> socket:[98325]
lrwx------ 1 root root 64 2013-10-14 20:31 947 -> socket:[98330]
lrwx------ 1 root root 64 2013-10-14 20:31 948 -> socket:[98335]
lrwx------ 1 root root 64 2013-10-14 20:31 949 -> socket:[98341]
lrwx------ 1 root root 64 2013-10-14 20:31 95 -> socket:[73220]
lrwx------ 1 root root 64 2013-10-14 20:31 950 -> socket:[98348]
lrwx------ 1 root root 64 2013-10-14 20:31 951 -> socket:[98353]
lrwx------ 1 root root 64 2013-10-14 20:31 952 -> socket:[98358]
lrwx------ 1 root root 64 2013-10-14 20:31 953 -> socket:[98363]
lrwx------ 1 root root 64 2013-10-14 20:31 954 -> socket:[98368]
lrwx------ 1 root root 64 2013-10-14 20:31 955 -> socket:[98373]
lrwx------ 1 root root 64 2013-10-14 20:31 956 -> socket:[98378]
lrwx------ 1 root root 64 2013-10-14 20:31 957 -> socket:[98383]
lrwx------ 1 root root 64 2013-10-14 20:31 958 -> socket:[98412]
lrwx------ 1 root root 64 2013-10-14 20:31 959 -> socket:[98417]
lrwx------ 1 root root 64 2013-10-14 20:31 96 -> socket:[73225]
lrwx------ 1 root root 64 2013-10-14 20:31 960 -> socket:[98422]
lrwx------ 1 root root 64 2013-10-14 20:31 961 -> socket:[98428]
lrwx------ 1 root root 64 2013-10-14 20:31 962 -> socket:[98433]
lrwx------ 1 root root 64 2013-10-14 20:31 963 -> socket:[98438]
lrwx------ 1 root root 64 2013-10-14 20:31 964 -> socket:[98443]
lrwx------ 1 root root 64 2013-10-14 20:31 965 -> socket:[98450]
lrwx------ 1 root root 64 2013-10-14 20:31 966 -> socket:[98455]
lrwx------ 1 root root 64 2013-10-14 20:31 967 -> socket:[98460]
lrwx------ 1 root root 64 2013-10-14 20:31 968 -> socket:[98465]
lrwx------ 1 root root 64 2013-10-14 20:31 969 -> socket:[98470]
lrwx------ 1 root root 64 2013-10-14 20:31 97 -> socket:[73230]
lrwx------ 1 root root 64 2013-10-14 20:31 970 -> socket:[98475]
lrwx------ 1 root root 64 2013-10-14 20:31 971 -> socket:[98480]
lrwx------ 1 root root 64 2013-10-14 20:31 972 -> socket:[98485]
lrwx------ 1 root root 64 2013-10-14 20:31 973 -> socket:[98491]
lrwx------ 1 root root 64 2013-10-14 20:31 974 -> socket:[98496]
lrwx------ 1 root root 64 2013-10-14 20:31 975 -> socket:[98501]
lrwx------ 1 root root 64 2013-10-14 20:31 976 -> socket:[98518]
lrwx------ 1 root root 64 2013-10-14 20:31 977 -> socket:[98523]
lrwx------ 1 root root 64 2013-10-14 20:31 978 -> socket:[98528]
lrwx------ 1 root root 64 2013-10-14 20:31 979 -> socket:[98541]
lrwx------ 1 root root 64 2013-10-14 20:31 98 -> socket:[73235]
lrwx------ 1 root root 64 2013-10-14 20:31 980 -> socket:[98548]
lrwx------ 1 root root 64 2013-10-14 20:31 981 -> socket:[98553]
lrwx------ 1 root root 64 2013-10-14 20:31 982 -> socket:[98558]
lrwx------ 1 root root 64 2013-10-14 20:31 983 -> socket:[98563]
lrwx------ 1 root root 64 2013-10-14 20:31 984 -> socket:[98568]
lrwx------ 1 root root 64 2013-10-14 20:31 985 -> socket:[98574]
lrwx------ 1 root root 64 2013-10-14 20:31 986 -> socket:[98579]
lrwx------ 1 root root 64 2013-10-14 20:31 987 -> socket:[98584]
lrwx------ 1 root root 64 2013-10-14 20:31 988 -> socket:[98589]
lrwx------ 1 root root 64 2013-10-14 20:31 989 -> socket:[98594]
lrwx------ 1 root root 64 2013-10-14 20:31 99 -> socket:[73240]
lrwx------ 1 root root 64 2013-10-14 20:31 990 -> socket:[98599]
lrwx------ 1 root root 64 2013-10-14 20:31 991 -> socket:[98604]
lrwx------ 1 root root 64 2013-10-14 20:31 992 -> socket:[98609]
lrwx------ 1 root root 64 2013-10-14 20:31 993 -> socket:[98614]
lrwx------ 1 root root 64 2013-10-14 20:31 994 -> socket:[98643]
lrwx------ 1 root root 64 2013-10-14 20:31 995 -> socket:[98650]
lrwx------ 1 root root 64 2013-10-14 20:31 996 -> socket:[98655]
lrwx------ 1 root root 64 2013-10-14 20:31 997 -> socket:[98661]
lrwx------ 1 root root 64 2013-10-14 20:31 998 -> socket:[98666]
lrwx------ 1 root root 64 2013-10-14 20:31 999 -> socket:[98671]
