david2010
Oct 12, 2015Tutor
Can't update 102 to firmware 6.4.0
I have tried using the NAS webpage (FIREFOX) to auto update and also a manual update of downloaded firmware without success. The unit uploads the image and prompts a reboot to install yet it doesn't...
david2010
Oct 12, 2015Tutor
Hi The current firmware is 6.2.5
Yes I have tried a different browser, I have had a message from Christine (support) that suggests the checksum fails when it verifies the update.
thoschnei
Oct 13, 2015Aspirant
I do have exactly the same problem. ReadyNas 102 on 6.2.5 won't update to 6.4.0. I tried twice and it downlodas the package ok but nothing happens on the next reboot. Still on 6.2.5
- EskenderNGOct 13, 2015NETGEAR Employee Retired
Hello,
first of all this is a good occasion to perform a backup of all your data before proceeding.
Failed FW upgrades can lead to data loss so please do a backup now if you have not done so already.
With failed FW upgrades it is also advisable to contact support as your case might be different from what I experienced and you may run into problems.
In my case I had a checksum mismatch when trying to upgrade from 6.2.5 to 6.4.0. My problem was solved by downgrading to 6.2.4 first and the upgrading from 6.2.4 to 6.4.0.
Bye,
Eskender
- david2010Oct 13, 2015Tutor
how do I downgrade to 6.2.4? Ive downloaded the firmware and manual uploaded and it doesnt install
- kohdeeOct 13, 2015Administrator
I just checked the build.log for 6.2.5 and see no changes that would have caused the checksum error on 6.2.5 that would inadvertently work in 6.2.4. I'm curious if more people resolve this issue with this method.
