mito1
Jan 08, 2012Aspirant
Can't upgrade a necessary library
Hi there, I try to run a programm on my ReadyNas but I have problems with a necessary library: ReadyNAS:/usr/sbin/kissdx# ./kissdx -v ./kissdx: error while loading shared libraries: libdvdread.so....
Thomas_xh1
Jan 09, 2012Tutor
By the default, there are only 2 files under /usr/lib
libdvdread.so.3 libdvdread.so.3.2.1
and did you means you need 5 files under the /usr/lib
libdvdread.a libdvdread.so libdvdread.so.3.2.1
libdvdread.la libdvdread.so.3
If yes, please run "apt-get update" at first, and then run command "apt-get install libdvdread-dev"
