mito1
Jan 08, 2012Aspirant
Can't upgrade a necessary library
Hi there, I try to run a programm on my ReadyNas but I have problems with a necessary library: ReadyNAS:/usr/sbin/kissdx# ./kissdx -v ./kissdx: error while loading shared libraries: libdvdread.so....
mito1
Jan 09, 2012Aspirant
It doesn't matter. I did "apt-get update" als well as "apt-get upgrade". The result is the same as in the starting post: "libdvdread-dev is already the newest version. ..."
And I don't know why there are more files than you are mentioned. I'll get them during the install ...
