tlgerdes
May 01, 2015Aspirant
Cant upgrade from 6.1.8 !!!!!
Ok guys, girls and others My 314 wont let me upgrade. When I log in with either IE or Chrome it prompts me to upgrade from 6.1.8 to 6.2.2, I hit the OK button, flashes a downloading screen for 5 se...
mdgm-ntgr
May 15, 2015NETGEAR Employee Retired
Do you have a backup?
If so, one option would be to:
1. Verify your backup is good
2. Do a factory default (wipes all data, settings, everything)
3. Update to the latest firmware
4. Verify the firmware update was successful
5. Do another factory default to get a clean setup on the new firmware
6. Restore your data from backup.
The new version of the Transmission app ( 3.00.8 ) does not have the issue the old version (3.00.6) did. So you could also install the new version of the Transmission app.
