emerson8
Jan 06, 2012Aspirant
can't upgrade or reboot ?
Hi,, been using a Readynas Pro 6 with fw; 4.2.20-T19 for a while, thought I'd update to 4.2.20-T23 but that doesn't seem to work for me. Download the updated, uploaded it to the readynas, applied it...
mdgm-ntgr
Jan 06, 2012NETGEAR Employee Retired
So have you installed EnableRootSSH? If so are you making sure you are trying to connect as the 'root' user? If you haven't installed EnableRootSSH you won't be able to SSH in.
You still have the issue with Frontview if you clear your web browser cache (e.g. Temporary Internet files)?
Perhaps try an OS Re-install: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
P.S. In future, please post about problems you encounter with beta firmware releases in the beta forum.
