wagb4
Sep 07, 2014Aspirant
Can't Use NFS to Access Home Shares
ReadyNAS model 102, Firmware version 6.1.8 - Tried to mount (on Linux) via entry in fstab a user's home folder and I get the error: mount.nfs: access denied by server while mounting <IP address / user...
mdgm-ntgr
Sep 11, 2014NETGEAR Employee Retired
Yes, well the last factory default (in this case on initial setup) and the subsequent firmware updates and OS Re-installs are logged in initrd.log
Seeing you haven't put data on yet, I would suggest you do a factory default e.g. via System > Settings > Update > Perform Factory Default in the Dashboard.
This will give you a clean setup on 6.1.8. After doing that can you enable NFS for your home shares and see if it works any better for you?
