yarrum
Nov 03, 2012Aspirant
Case sensitive folder names
Odd issue regarding front view backup job. Setup - ReadyNAS Duo (V1). Radiator 4.1.10, USB drive attached to rear port, backup job to backup one share (50 gig) to the USB disk (NTFS format), target f...
mdgm-ntgr
Nov 03, 2012NETGEAR Employee Retired
Not odd at all. Folder names are case-sensitive on Linux. You should specify the backup source and destination correctly in the backup job properties.
Btw if you're running RAIDiator 4.1.10 you have a Duo (v1) not a Duo v2. See How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
