yarrum
Nov 03, 2012Aspirant
Case sensitive folder names
Odd issue regarding front view backup job. Setup - ReadyNAS Duo (V1). Radiator 4.1.10, USB drive attached to rear port, backup job to backup one share (50 gig) to the USB disk (NTFS format), target f...
mdgm-ntgr
Nov 03, 2012NETGEAR Employee Retired
Actually the NTFS filesystem supports case-sensitive names for files/directories. If it didn't then what happened in your case wouldn't have been possible.
Yes there are limitations on the Windows side that mean naming two folders/files with the same name except for the case of some letters isn't a good idea.
