yarrum
Nov 03, 2012Aspirant
Case sensitive folder names
Odd issue regarding front view backup job. Setup - ReadyNAS Duo (V1). Radiator 4.1.10, USB drive attached to rear port, backup job to backup one share (50 gig) to the USB disk (NTFS format), target f...
mdgm-ntgr
Nov 03, 2012NETGEAR Employee Retired
StephenB wrote:
You probably should take a moment to update your profile though, as people responding to any future posts you make will assume the model in your signature is correct.
+1
