cs_giuseppe
May 25, 2017Apprentice
Change Samba idmap with AD
Hi I have a nas that was installed long ago with a firmware pre 6.5 and then upgraded to the last, with this nas the idmap with ad is different that one started with a recent firmware. It's poss...
- May 31, 2017
Hi,
SOLVED !!!
here the step
- Switch from AD to Local users.
- NEW - Disabled samba in each share
- Wipe the permissions under File access tab / reset of each shares settings section.
- Edit /etc/samba/smb.conf to replace tdb by: rid
- Execute: net cache flush
- NEW - Reboot
- Join AD with "trusted domain" unchecked.
After these steps now idmap use rid.
Thank for all suggestions
jak0lantash
May 25, 2017Mentor
I would:
- Check smb.conf that it's using rid instead of tdb.
- Reapply the permissions: https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions
If smb.conf still uses tdb, I can try to confirm how to manually change it.
cs_giuseppe
May 27, 2017Apprentice
Hi jak0lantash,
thank for the suggestion
made:
- Switch from AD to Local users - done
- Set file owner to guest and group owner to guest - done
- Wipe the permissions under File access tab / reset of each shares settings section. - done
- Deleted the nas account on domain - done
- Join AD with "trusted domain" unchecked. - done
- Check smb.conf that it's using rid instead of tdb. - NO, still idmap config * : backend = tdb
I
