cs_giuseppe
May 25, 2017Apprentice
Change Samba idmap with AD
Hi I have a nas that was installed long ago with a firmware pre 6.5 and then upgraded to the last, with this nas the idmap with ad is different that one started with a recent firmware. It's poss...
- May 31, 2017
Hi,
SOLVED !!!
here the step
- Switch from AD to Local users.
- NEW - Disabled samba in each share
- Wipe the permissions under File access tab / reset of each shares settings section.
- Edit /etc/samba/smb.conf to replace tdb by: rid
- Execute: net cache flush
- NEW - Reboot
- Join AD with "trusted domain" unchecked.
After these steps now idmap use rid.
Thank for all suggestions
cs_giuseppe
May 27, 2017Apprentice
Hi jak0lantash,
thank for the suggestion
made:
- Switch from AD to Local users - done
- Set file owner to guest and group owner to guest - done
- Wipe the permissions under File access tab / reset of each shares settings section. - done
- Deleted the nas account on domain - done
- Join AD with "trusted domain" unchecked. - done
- Check smb.conf that it's using rid instead of tdb. - NO, still idmap config * : backend = tdb
I
jak0lantash
May 27, 2017Mentor
I wish this would behave differently...
Try to edit smb.conf to replace tdb by: rid
Then: net cache flush
Then start the steps again. If you get to rid, the mapping table should be calculated consistently across both devices.
- cs_giuseppeMay 27, 2017Apprentice
Hi
tried it but no change, still tdb
Thanks
- jak0lantashMay 28, 2017Mentor
Please confirm if these are the steps you followed:
- If so, reapply the permissions: https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions
- cs_giuseppeMay 30, 2017Apprentice
Hi,
I'm setting a test enviroment with a virtualbox nas for testing so I don not touch many the main production nas.
Keep you updated
Thanks for all support
